Calculating Forces and Torques in a Basic Equilibrium Problem
  • Thread starter Thread starter Matt Armstrong
    Equilibrium
4 replies · 2K views
Matt Armstrong
A sturdy wooden plank, 4 meters in length and having a mass of 42 kg, is rests on 2 supports placed 1.2 meters from each end. Suppose a man of 72 kg stands 1 meter from the right end of the board. What are the upward forces on each board?
|---L----R-M--|
Where L is the left support, R is the right support, and M is the man.
ΣFy = 0
Στ = 0
τ_R = F_R * .8, τ_L = F_L * .8
Total gap between supports is 1.6 meters.
Weight of man = 705.6 N
Weight of board = 411.6 N
Each support is located .8 meters away from the board, and thus I have written out those equations above. I know that the torque produced by the man is equal to his weight, as he is 1 meter away from both the center and the edge of the board, and I am assuming the torque of the board is also equal to its weight. I also know that in problems similar to this, like cantilevers, the force of the left support will actually be downward, instead of upward.
I know that if I have the force of the right support, I can figure out the support of the left. At first, I tried to figure the force of the right support out by adding the torques of the man and board together and then solving for F_R, but in hindsight I am not confident that is the correct way to go about it.
Hello,
As I can see, you have written the ΣFy=0 equation but you have not used it.
It's a support. By definition, it can only exert an upward force on the plank.
Sounds good. Please post your attempt.
There being no horizontal forces, there are only two equations available. Doesn't matter whether they are two torque equations or one torque and one linear.
.8*F_R = T_M + T_B = 705.6 + 411.6 = 1117.2 -> 1117.2/.8 = 1396.5 = F_R
1396.5 + F_L - F_M - F_B = 0, with F_L resulting as -279.3, but it needs to be an upward force?
