Calculating G Forces or the Centripical force
  • Thread starter Thread starter fastlane51
    Force Forces
This discussion focuses on calculating G forces and centripetal force for a vehicle in motion, specifically using the formula F = (m*v²) / R. Participants clarify that the angle measurement (theta) can be expressed in either radians or degrees, with a conversion factor of 180 degrees equating to π radians. A practical example is provided, where a vehicle with a mass of 1465 kg experiences 1.9 G forces during a turn with an arc length of 200 meters and a speed of 15.6 m/s. The radius of the turn is calculated to be approximately 127.32 meters using the relationship between arc length and angle.
  • Understanding of centripetal force and acceleration
  • Familiarity with the formula F = (m*v²) / R
  • Knowledge of unit conversions, specifically mph to m/s
  • Basic trigonometry, particularly angle conversions between degrees and radians
  • Learn about the physics of circular motion and centripetal acceleration
  • Study the relationship between arc length, radius, and angle in circular motion
  • Explore practical applications of G force calculations in automotive engineering
  • Investigate tire performance curves and their impact on vehicle cornering efficiency
Physics students, automotive engineers, and anyone interested in understanding the dynamics of vehicle motion and G forces during turns.
fastlane51
Hi I am brandon and I am new to this forum! I am mainly a chemistry guy and that's what I am good at in my college but I want to learn about physics too!
How would I go about calculating the G forces or Centripical force in a vehicle in motion if I know the degree of the turn, the weight of the car, and the length of the arc?
I need to know what units to use but to my knowledge i use Kg, M/s, and radians??
DO I use radians as the units for the degree of the arc?
So I have " F= ( m*v^2 ) / R "
And for the radius I have " R= s/ theta" where theta is the angle measurement, BUT WHAT IS THE MEASUREMENT IN ? RADIANS? DEGREES?
I got 2800 kg of force put on the side of my car which is 1.9 G forces with radians...
mass of car- 1465
arc length- 200 meters
Arc angle - 90 degrees
Speed- 35 miles an hour or 15.6 meters per second
Can anyone tell me what i should get?
fastlane51 said:
Do I use radians as the units for the degree of the arc?
It's not needed. What you need is the ratio of arc length versus circumference. Knowing that there are 360 degrees in a circle, or that there are 2 \pi[/tex] radians in a circle would allow you to use either unit.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> 2800 <b>units</b> of force </div> </div> </blockquote>What unit of force is equal to 1 kg m / sec^2?
hi.
im also new here
the law is
theta (in radian)= length (of the arc)/thr redius
theta here : is the central angle ( the measure of the arc)
so by this law we can get the redius length and use it in the law
f= m*v^2/r
to get the centrepital force
and from degree to raadian
(theta in radian / the (by) constant= theta in degree/180)
90 degree =1.57radians approximatly
200/1.57=127.3m approxmatly
here we can complete the problem
that what i think
Force is a measure mass times acceleration which in SI units is expressed as (kg) * m/s² or N (Newtons).
In acceleration due to a circular path like an auto on a curved roadway, the dimension of interest would be the radius of the curve as the centripetal acceleration would be expressed as v²/r. If you express your v²/r in terms of g then you can simply apply that g factor to whatever mass you may be dealing with.
For example 60 mph on a 100 m radius curve will be
(60*.447)² /100 = 7.2 m/s² of acceleration
(.447 is mph to m/s conversion factor)
divide that by 9.8 m/s² which is gravity and that = .73 g
Then you can apply that g factor to whatever kgs of mass you have and get the force directly.
mass of car- 1465
To determine the radius from the arc and angle you suggest use the simple relationship that there are 2π radians in a circle. (The number of radii in a circumference.)
If a 1/4 circle is 200 m then your circumference from 90° ... 200*4 = 2π*r
r = 800/2π = 127.32 m
mass of car- 1465
" F= ( m*v^2 ) / R " is correct formula
one more piece to ponder..
from our cone killing days in SCCA Autocross..skid pad testing ,,go to parking lot, airport,,what ever, set up circle 200 to 300 feet in diameter, drive around the cirle as fast as you can without spinning out..
G = 1.225 x R / T squared
R= Radius of the turn in feet
T = Time in seconds to complete a 360 degree turn
typical Corvette corners at .84gs
road race sedan like Tran Am 1.15 Gs
if you know the tire performance curve from the manufacturer charts weight (vertical load in static pound) vs Traction (lateral load in lbs) you can calculate the Cornering efficiency
  • · Replies 20 ·
