Undergrad Calculating Headwind Component for Trigonometric Wind Triangle Problem
  • Thread starter Thread starter Cristiano
    Component
The discussion centers on calculating the headwind component in a trigonometric wind triangle problem, specifically seeking a general procedure or algorithm. The user provides examples with varying wind directions and ground tracks but struggles with consistent calculations. Suggestions include using vector components to simplify the process, allowing for the addition and subtraction of vectors without multiple cases. An addendum reveals that the user has found a formula for the angle between two vectors, but notes it is not efficient. The conversation emphasizes the need for a streamlined approach to determine the angle between wind and aircraft speed.
Cristiano
This is a question about the well known trigonometric problem of the wind triangle, but my problem is just the calculation of the head wind component.
I don't know how to write a general procedure to find the angle between the wind and the speed of the aircraft (the so called ground speed).
Suppose that the wind direction WD= 120° and the ground track GT= 40°; the wind direction is always *from* x degrees, then I need to consider WD + 180= 300; the angle is GT - 300 + 360= 100°.
Now suppose that WD= 40° and GT= 120°; the above formula doesn't work; in this case I just need to do (WD + 180) - GT.
Please, could someone help me in finding a general procedure to do that?
Thank you
Mathematics news on Phys.org
You don't need to do all this. Just draw a diagram and everything becomes obvious.
What angle are you trying to find out, anyway?
And what is ground track? The speed of the plane relative to the ground?
I already do that by hand, but the problem is that I need to find a general procedure or an algorithm (few lines of C code).
I need something like this:
1) calculate angle= (WD + 180) - GT
2) if angle > 360 then angle= angle - 180
3) if angle < 0 then angle ...
4) ...
but it's just an example.
The angle between the wind and the aircraft.
Yes.
Why don't you use components to add or subtract the vectors? Then you don't need to have different cases.
If you write the x component of vector a (for example) as ax=a cos(theta) where theta is the angle with the horizontal, ax will be negative when the angle is between 90 and 270 degrees. You add the x components and the y components and the signs will tell you in what quadrant is the angle of the resultant. And the inverse tangent will give you the value of the angle.
Probably I didn't get your point; let me try an example.
Suppose that we have the vector g (ground speed) = 450 and the vector w (wind) = 50.
The angle gt for g is 20° and the angle wt for w is 150°. The correct result is 150 - 20 = 130.
I do:
x= g * cos(gt) + w * cos(wt)
y= g * sin(gt) + w * sin(wt)
atan(y / x)= 25.2°.
== Addendum ==
In the meanwhile, I use the formula for the angle between two vectors:
gx= g * cos(gt), wx= w * cos(wt)
gy= g * sin(gt), wy= w * sin(wt)
cos(a)= (gx * wx + gy * wy) / g / w
which correctly returns 130°, but it's not very efficient.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 16 ·
