Calculating Impulse in a Collision: Positive or Negative Velocity?
  • Thread starter Thread starter ph_lover3294
    Impulse
The discussion revolves around calculating impulse in the context of a collision involving a tennis ball and a racket. The original poster presents a scenario where the ball has an initial velocity and a final velocity after rebounding, seeking clarification on the correct application of velocity signs in the impulse formula.
  • The original poster attempts to understand when to use negative velocity in calculations, questioning whether to consider the final velocity as negative or positive based on direction. Some participants suggest defining a consistent sign convention for clarity.
Participants are exploring the implications of sign conventions on the calculation of impulse. There is a recognition of differing interpretations and confusion stemming from various sources, but no consensus has been reached yet.
The original poster expresses uncertainty due to conflicting answers found in textbooks, indicating a need for further clarification on the change in velocity and its implications for impulse calculation.
ph_lover3294
a tinnes ball of mass 150 gm moves with velocity 11.2 m/s to collide with a racket , after collision it is rebounded with vilocity 7 m/s ...find :-the impulse of the racket on the ball.
I = m (delta) v
what i want to know .. is
when do we use the vilocity with the negative direction ??
i mean when we answer it
can we calculate
0.15 * ( 11.2-7)= 0.63 kg.m/s
or
0.15* (11.2-(-7))=2.73 kg.m/s
so what is the right answer ?!
Think about it. If we define the direction of the initial velocity to be positive, than what must the sign of the resultant final velocity be?
Hint: The ball's final velocity is opposite in direction to it's initial velocity.
i know
i thought that second answer is the right one as it is opposit in direction
but i found different answers in the books so i got confused
but also i want to understant ... we want to find the change in velocity so when we give the final one -ve sign we will add them so how ?
im sorry I am asking a lot of questios
thank u
The change in velocity is always Vfinal - Vinitial.
The direction that you call negative is arbitrary. For example, if you call toward the racket as positive, then away from the racket must be negative.
Pick a sign convention, then determine Vfinal and Vinitial.
thank u
  • · Replies 17 ·
9K
