Calculating km/hr from engine rpm
  • Thread starter Thread starter sozener1
    Engine Rpm
The calculation of speed in km/hr from engine RPM involves understanding the gear ratio, wheel diameter, and the relationship between crankshaft and wheel revolutions. Given a gear ratio of 13.579 and a wheel diameter of 0.6m, the correct method is to divide the engine RPM (1500) by the gear ratio to find the wheel RPM, which results in approximately 100 RPM. This translates to a speed of about 12 km/hr, confirming that the initial high estimate of 2000 km/hr was incorrect. The weight of the car and transmission efficiency do not factor into this specific speed calculation.
  • Understanding of gear ratios in automotive engineering
  • Basic knowledge of rotational motion and RPM calculations
  • Familiarity with the formula for calculating distance from wheel revolutions
  • Knowledge of metric conversions, specifically from meters to kilometers
  • Study the principles of gear ratios and their impact on vehicle speed
  • Learn about calculating speed from RPM in different transmission systems
  • Explore the effects of vehicle weight on acceleration and performance
  • Investigate the role of transmission efficiency in overall vehicle dynamics
Automotive engineers, mechanics, students studying vehicle dynamics, and anyone interested in understanding the relationship between engine RPM and vehicle speed calculations.
sozener1
the gear ratio between crankshaft and driveshaft calculates to be 13.579 at first gear
the diameter of the car wheel is 0.6m
the transmission efficiency is 0.85
weight of the car is 1200kg
if the engineer is running at 1500rpm how do you calculate the speed in km/hr generated by the engine
since gear ratio is 13.579 I multiplied it to 1500 rpm then by 60 to get revolutions per hour
and I multiplied result by (0.6*pi) to obtain the distance it traveled in an hour.
then I get something like 2000km/hr which I think is ridiculously high?
so I tried to divide 1500rpm by the gear ratio and then calculated, then I get somting like 12km/hr which I think is too low.
what have I done wrong
You need to divide the engine RPM by 13.579 to get the wheel RPM. For every 13.579 revolutions of the crankshaft, the wheel goes around once.
So by very rough calculations, at 1500 RPM the wheels are turning at about 100 RPM. Each revolution of the wheel is ~ 2m, so the wheels are covering about 200 m/min. That works out to 12,000 m/hr or about 12 Km/hr, which is the same as what you got.
I think this is a reasonable result. The transmission in this vehicle is geared extremely low. With gearing this low, you could probably pull stumps out. The gearing for cars is typically in the range of about 3.0:1 to 4.5:1. Also, at 1500 RPM, the engine isn't turning very fast, with idle being somewhere around, say 800 RPM. A lot of cars have a redline above 6500, and some motorcycles have redlines up around 12,000 - 14,000 RPM.
Some of the data you posted is extraneous -- the weight of the car doesn't enter into these calculations, although it does play a role in the acceleration. Also, the transmission efficiency doesn't play a role, although it does affect the power at the rear wheels.
thank you so much for the detailed explanations it really helped
  • · Replies 17 ·
  • · Replies 32 ·
