Calculating Magnetic Field Outside Toroidal Solenoid
  • Level: Undergrad
  • Thread starter Thread starter LordBerkley
    Solenoid
1 reply · 3K views · last reply
LordBerkley
If I have a solenoid in the shape of a toroid (i.e. solenoid joined end to end) the magnetic field produced by the flow of charge will produce a concentrated magnetic field within the coil.
How would I go about calculating the size of the magnetic field outside of the coil due to magnetic field leakage?
Any advice much appreciated.
LB
LB
I think that a good approximation would be to assume that the magnetic field [itex]\vec{B}[/itex] inside the soldenoid is directed perpendicular to the plane of each coil and is zero outside of the solenoid. Then you can use Ampere's law to compute it:
[itex]\int B \cdot d\mathcal{l} = \mu I[/itex]
The meaning of that equation is that if you imagine drawing a closed loop that encloses a bunch of wires, then the total current enclosed by the loop is equal to the line integral of [itex]B[/itex] around the loop.
