Calculating Mechanical Energy Lost Due to Friction on Inclined Plane
To calculate the mechanical energy lost due to friction on an inclined plane, start by determining the potential energy (PE) at the top using mgh and the kinetic energy (KE) at both the top and bottom using 1/2 mv^2. The energy lost to friction can be found by subtracting the KE at the bottom from the total energy at the top, which includes both PE and KE at the top. The calculations yield a mechanical energy loss of 37.2 J due to friction. This approach effectively illustrates the relationship between potential energy, kinetic energy, and energy loss in a frictional context.
Amel
Ok so the rpoblem is A 2.20kg box slides down a rough incline plane from a height h of 1.63m. The box had a speed of 2.33m/s at the top and a speed of 1.90m/s at the bottom. Calculate the mechanical energy lost due to friction (as heat, etc.).
and I am not sure where to even begin with this one. its my last problem I need to finish.
At the top you have kinetic energy and potential energy.
At the bottom you have kinetic energy.
The difference is energy lost to friction
hint work (energy) = force * distance
So do you do (1/2)mv^2 for both speeds? and find the difference?
or do you use mgh= PE
Ok thanks I got it right.
Both
do the 1/2 mv^2 for the KE at each end, then take off the 'mgh' the stuff that's left must have gone to friction
Yeah I got it. mgh is PE and .5mv^2 is KE at the top then you have .5mv^2 at the bottom and find the difference. got 3.72e+01 J. and it was right.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
