Calculating minimum reserve factor in an I-beam
  • Thread starter Thread starter Jadamog
    Minimum
To calculate the minimum reserve factor, or safety factor, for an I-beam clamped at both ends, it's essential to know the yield strength of the material, which is distinct from the modulus of elasticity. With the maximum bending stress and cross-sectional area already determined, the next step involves using these values along with the material's strength characteristics. Creating a Goodman diagram may be necessary to assess the number of cycles to failure, especially when considering fatigue. Understanding these concepts will help clarify the process of calculating the safety factors. Properly applying these principles will enable accurate calculations for the I-beam's performance under load.
Jadamog
Hi Everyone, I am confused about how to calculate the minimum reserve factor against yielding and fatigue in an I-beam clamped at both ends. I have calculated the maximum bending stress from it's deflection due to a load in the middle of the beam, and I know the cross-sectional area of the I-beam. Is it now possible to calculate the reserve factors?
If by 'reserve factor' you mean 'safety factor', you would need to know the strength characteristics of the material used to fabricate the beam, i.e. its yield strength. Yield strength is not the same as modulus of elasticity.
Thanks for the reply, yes I do mean the safety factor. And I do have all the strength characteristics of the beam, sorry I forgot to mention that in the original post. So is it now possible to calculate the safety factors?
Sure. Go ahead.
SteamKing said:
Sure. Go ahead.
Ha, I would if I know exactly what I was doing but I'm still confused on how to get started, do I have to create a Goodman diagram to see how many cycles to failure first?
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 30 ·
  • · Replies 16 ·
