Calculating Molar Concentration for Beers Law Plot
10 replies · 6K views
jpd5184
hello everyone, i need to do a beers law plot. i got the percent transmittance which i converted to absorbance but I am not sure how to get the molar concentration.
i found the max wavelength to be 515 nm. I prepared three 8-10ml diluted solutions by mixing a standard solution x (0.100M) and distilled water in ratios of 3:1(6ml standard solution, 2ml water),1:1(5ml of standard solution, 5ml water), and 1:3(2ml standard solution, 6ml water). i measured the absorbance of each of these diluted solutions and the max wavelength and got
3:1 diluted solution 0.294
1:1 diluted solution 0.466
1:3 diluted solution 0.143
i know that molarity = (moles of solute)(liters of solution)
how do i know what the liters of solution is and the moles of solute?
If you mix 5 mL with 2 mL, what volume will you get? (at least approximately)
it would be 7ml. so would i just multiply the added volumes by the molar concentration to get molarity.
i tried this but when i graphed it, it was not a straight line which it should be.
sorry,
its molarity=(moles of solute)(liters of solution)
the one thing i don't get is the beers law graph is absorbance vs molar concentration. so i know the liters of solution for each but don't know the moles.
moles of solute=(molarity)/(liters of solution)
would this be correct
jpd5184 said:
sorry,
This is still wrong, you should divide, not multiply. Concentration is an amount of substance per volume.
i know its division i could have sworn i put the backslash in there but i quess not. so i know the equation so what volume do i use. would it be the 8ml,10ml, and 8ml in the three solutions
8/10/8 looks like a correct final volumes.
so i have the volume and absorbance of each solution, and the molarity of the standard solution.
to graph absorbance vs molarity i need molarity of each solution. to find this out i need to know the moles of each solution so i can divide it by liters to get molarity.
so would i just take the molarity of the standard solution and divide that by the volume of each diluted solution to get moles. but then what volume do i divide this by to get molarity.
just not sure if I am thinking correct or not
No, you don't divide molarity by volume. You divide NUMBER OF MOLES by volume.
And number of moles is volume times concentration. C=n/V, simple algebra and solving for whichever variable is all you need.
so this is what i did.
i took the moles of standard solution used and multiplied by the molarity of the standard solution to get a number and then divided that number by 100ml to get my molarity
does that sound correct?
