Calculating net force from a diagram
13 replies · 4K views
pbonnie
Calculate the net force acting on each object indicated in the following diagrams.
c^2 = a^2 + b^2
sinA/a = sinB/b = sinC/c
c^2 = a^2 + b^2 - 2abcosC
Fnet =?
Fnet(v) = 8.0 N [N] + 10.0 N
= 10.0 N - 8.0 N [N]
=2.0 N
I'm not sure what to do after this.
I know the angle opposite the 45° is 180° - 45° = 135°
But I'm not sure how to add the 17 N vector and the 2.0 N vector.
Please help!
Welcome to PF pbonnie!
That diagram is really tiny!
Anyway, remember that vectors add "tip to tail" so you slide the 2.0 N southward vector over until its "tail" touches the "tip" of the 17.0 N northwest-ward vector. The resultant then goes from the tail of the 17.0 N to the tip of the 2.0 N. So these three vectors form a triangle, in which you know two of the sides and one angle. This should be enough to apply the cosine law, right?
Thank you for the quick reply!
Sorry for the tiny picture.
Does the 135° angle sit at the corner of 2.0 N and 17.0 N vector?
So like this? (picture attached, hopefully normal sized!)
Well, yeah, sort of. The angle at that vertex of the triangle is 45 degrees. What you have is 180 minus that, but we want the interior, acute angle, not the exterior one.
Another way to think about it is that the 17.0 N vector is angled 45 degrees from the vertical, and the 2.0 N vector is vertical. Hence the angle between them is...45 degrees.
Ohh okay. I thought that didn't seem right.
So then I could do cosine law..
c^2 = 2.0N^2 + 17.0N^2 - 2(2.0N)(17.0N)cos45°
*showing work on actual sent in work*
c = 15.6 N
then find the angle of the vector using sine law, so..
sinA/2.0N = sin 45/15.6N
*show work*
A = 5°
The net force is 15.6 N [W 5° N]?
c = 15.6 N
*show work*
A = 5°
I agree with your magnitude. Your direction is wrong. Ask yourself: WHICH angle are you measuring when you use the sine law like that? You're measuring the one IN the triangle. But this is the angle between the resultant vector and the 17.0 N vector. What you want is the angle between the resultant vector and the horizontal.
Hint: the 17.0 N vector is 45 deg. from the horizontal. You know the angle between the 17.0 N vector and the resultant. Therefore, you know the angle between the resultant and the horizontal. :wink:
Hmm.. I don't think I understand. What is the horizontal?
I'm calling the east-west direction "horizontal" and the north-south direction "vertical", because this is the way they are oriented on your piece of paper.
Horizontal. Flat: ----------------------------------
So you can't say that the angle you got is "north of west" because you're not measuring it relative to due west. You should be. Draw a picture.
So the resultant is also 45 degree from the horizontal? I drew a picture but I don't know how to figure out the angle.
Nope, the 17.0 N vector is 45 from the horizontal. The resultant vector is few degrees below that (as you can see from your triangle). And you know how many degrees below that, because you just calculated it.
Oh! So the angle between the resultant and the horizontal would be 5 + 45, so 50°.
Then it's 15.6 N [W 50° N]?
pbonnie said:
Or sorry, it would be 45 MINUS the 5, so 40
Correct! If you're facing due west, you need to rotate towards the north (clockwise) 45 deg to be facing in the direction of the 17.0 N vector. But if you were trying to find the direction of the resultant vector, then you've gone too far, and you need to rotate back (counterclockwise) by 5 deg. Hence the answer is 45 - 5.
