Calculating Net Gravitational Force Between Multiple Objects
The discussion revolves around calculating the net gravitational force between multiple objects, specifically a 200 kg object and a 500 kg object, with a 50.0 kg object placed midway between them. Participants are exploring the application of gravitational force equations in this context.
  • Mixed
  • Participants are attempting to apply the gravitational force formula, questioning the setup and calculations involved. There is a discussion about the correct value of the gravitational constant and whether to subtract the masses in the calculations.
Some participants have provided guidance on using the correct gravitational constant and suggested calculating forces separately before combining them. There is an ongoing exploration of different interpretations of the problem setup and calculations.
Participants are addressing the confusion around the use of 'little g' versus the gravitational constant 'big G', and there is a mention of the need for clarity on how to approach the calculation of net forces between the objects.
phyhelpme
Confused :(
A 200 kg object and a 500 kg object are separated by 0.500 m. Find the net gravitational force exerted by these objects on a 50.0 kg object placed midway between them.
We don't spoonfeed homework here. Show your attempts.
I have:
F= Gm1m2/r^2
F= G(50.0kg)(500kg-200kg)/0.25m^2 =240000N toward 500kg
I feel that I have it setup right but for some reason when I calculate I get 2400000 which seems wrong to me.
phyhelpme said:
I have:
F= Gm1m2/r^2
What value have you used for G?
9.8 m/s^2
phyhelpme said:
9.8 m/s^2
That's little g. You want http://en.wikipedia.org/wiki/Gravitational_constant" .
Any advice on how I find it?
Your working the same problem?
The easiest way, I would think, would be to click on the link DaveC provided under 'big G'. :smile:
If it was a snake it would have bitten me.
So G is 6.674 x 10^-11N (m/kg)^2 correct?
That would mean my equation is:
F= 6.674 x 10^-11(50.0kg)(500kg-200kg)/0.25m^2 =1.60176 x 10^-5N toward 500kg?
No, you don't subtract the masses.
Calculate the forces separately, between the 200&50 kg masses, and then between the 500&50 kg masses. Then use vector addidtion to add these two forces together. Important: add the forces as vectors, don't just add the two numbers together.
  • · Replies 28 ·
  • · Replies 18 ·
