Calculating Net Work Done by 500g Mass on Unstretched Spring
The problem involves a 500 g mass attached to an unstretched spring with a spring constant of 10 N/m. The mass is released, and the question seeks to determine the net work done on the mass from the point of release to the lowest point it reaches.
  • Participants discuss the application of the work-energy theorem and potential energy changes, questioning the interpretation of net work as zero due to velocity being zero at both points. There are suggestions to equate gravitational potential energy change with spring potential energy change.
The discussion is ongoing, with various interpretations being explored regarding the net work done. Some participants express confusion about the concepts of work and energy, while others provide guidance on considering the forces acting on the mass and the implications of potential energy changes.
Participants note the pressure of an upcoming exam and the challenges of understanding the material, which may influence their engagement in the discussion.
habibclan
A mass of 500 g is attached to the bottom of an unstretched spring attached to the ceiling, and has a spring constant 10 N/m. The mass is then released. What is the net work done on the mass between the point where it was released and the lowest point that it reaches?
Wnet= F.d
The point at which it is released, v=0 and the lowest point is a turning point therefore v=0. So Wnet=delta K= 0 as velocity is 0 both times. Would the work done be 0 J then? Thanks in advance for any help!
This is also why there is a "work-potential energy theorem":
W = - delta_PE .
This is the work done by each force. Consider that there are two acting on the mass, gravity and the spring's restoring force, so you'll need to look at the change in potential energy for each as the mass goes from one rest point to the other.
(There is a more precise way to describe this situation using mechanical energy conservation, which may clarify things further.)
0 J? Are you serious? I think you are maybe asking too many questions and not thinking enough. This has afflicted people on this forum before. Don't let yourself be one of them. Why don't you equate gravitational potential energy change with spring potential energy change if v=0 at both points?
Sorry :$. It's just that I'm not really good with the concept of work. I read the textbook and did all the recommended questions but this was from a practice midterm. I'll try not to post as much now and try to think them through. But I only post questions if I try them at least 3-4 times and still don't get them! My exam being on Tuesday doesn't help much as I've got to cover everything in a few days =(.
Ok, but it still seems to me you could get more of these questions if you would just think harder. I believe you are pretty good. Some people do use PF as a substitute for thinking. Don't be one of them. 0 J? Really? Can you explain your thinking on that? Work=force*distance and work is relative to the force doing the work. If you think of gravity as doing the work then the result is negative the result of if you think of the spring doing the work. So maybe the correct answer is 0 J. So if net work=gravity plus spring then you are correct. Sorry for being so crabby.
I was thinking of the work-kinetic energy theorem were Wnet= delta K. But maybe I should always stick to the equation: Ki + Ugi + Wext= Kf + Ugf + Delta E (thermal), and plug in things to see where the conversion is occurring. My textbook gives too many formulas which creates a lot of confusion!
No, you already have it. In the sense you are talking about the net work is 0 J. You really basically understand most of the stuff you post. It's my problem that I don't understand that you already understand.
  • · Replies 58 ·
