Calculating P for an Aircraft Flying in a Circular Motion
An aircraft with a mass of 4.00 x 10^4 kg is flying in a horizontal circle at a constant speed of 250 m/s, with lift (P) acting at a 35-degree angle to the vertical and weight (W) calculated to be 3.92 x 10^5 N. To find P, the vertical component of lift must equal the weight, leading to the equation P * cos(35) = W. Rearranging gives P = W / cos(35), allowing for the calculation of lift. The discussion also touches on the need for additional information, such as radius or time, to fully solve the problem.
QuantumNite
An aircraft flies with its wings tilted, in order to fly in a horizontal circle of radius r. The aircraft has mass 4.00 x 104 Kg and has a constant speed of 250ms-1 . with the aircraft flying in this way, two forces are acting on the plane, P [lift] and W [weight which is given as 3.92*105 N] . P is acting at 35 degrees to the vertical. calculate P
centripetal force=mass * velocity2 / radius
centripetal force= mass * angular speed2 * radius
angular speed = theta / time
angular speed = velocity/ radius
angular speed = 2pi * frequency
centripetal acceleration = velocity2 / radius
centripetal acceleration = angular speed2 * radius
Force = mass * acceleration
I can't do it. I swear we need more information. can someone enlighten me.
QuantumNite said:
An aircraft flies with its wings tilted, in order to fly in a horizontal circle of radius r. The aircraft has mass 4.00 x 104 Kg and has a constant speed of 250ms-1 . with the aircraft flying in this way, two forces are acting on the plane, P [lift] and W [weight which is given as 3.92*103 N] . P is acting at 35 degrees to the vertical. calculate P
What information do you think you need?
By the way, I think the weight should be ##3.92*10^5N##. Personally I would do this question algebraically and just plug the numbers in at the end. That's also a good way to work out what quantities you do need.
Likes QuantumNite
yes I think that the weight is correct. I couldn't read the sheet correctly.
the info that I think we need : time or radius
I am not sure whether we need to plug it into an equation or just use trig??
You need to think about the forces involved. There's a key equation that will open up the whole problem. And, by equation I mean two quantities that must be equal.
Hint: why doesn't the plan fall out of the sky?
Likes QuantumNite
Correct me if I am wrong,
but can I say that the vertical component of P is PCos(35), and it doesn't fall out of the sky because Weight is equal to PCos(35)
Therefore, PCos(35) = 3.92 * 105
So, If we rearrange that equation, P = 3.92*105 / Cos(35) == 321107.6 [1dp]
Yes, that's it exactly. Although, I prefer:
##P = \frac{mg}{\cos \theta}##
or:
##P = \frac{W}{\cos \theta}##
Likes QuantumNite
or:
Thanks,
Could you please explain to me how you came to those equations?
QuantumNite said:
Thanks,
I just copied what you had done! I just used letters for the quantities involved instead of plugging in the numbers. There are a lot of advantages to this. Not least, once you plug in the numbers, you lose sight of what is related to what and if you make a mistake, well one number looks very like another, and it is hard to spot an error.
That said, I thought the question was to calculate ##r##. I see now that all you need is ##P##, which is a lot simpler.
Is part 2 of the question to calculate ##r##?
Yes it is.
but I am pretty sure how to do it
F=mv2 / r ,, rearrange for r
QuantumNite said:
Yes it is.
If you post your answer, I can show you the algebraic approach, which might be interesting and/or enlightening!
