MysticDream
- Messages
- 112
- Reaction score
- 9
- TL;DR
- Trying to understand Euler's turbine equation and velocity triangles.
I'm having a difficult time understanding Euler's turbine equation as it relates to designing a centrifugal air compressor. I need to calculate the impeller size if I know the inlet pressure, outlet pressure, rpm, and mass flow rate. The velocity triangles and definitions have me confused. It's the exit velocity of the air that I need to determine.
I have this equation for rate of work (power) from Euler's turbine equation:
$$P = \dot m(u_2c_2-u_1c_1)$$
where
u = tangential velocity of the impeller at inlet and outlet
c = absolute velocity of the fluid at inlet and outlet
I know I can use the formula for adiabatic compression to determine the power if I know the inlet volumetric flow rate, inlet pressure, outlet pressure, and RPM:
$$P = \left( \frac{(V_1P_1-V_2P_2)}{(\gamma-1)}\right)\left(\frac{RPM}{60}\right)$$
That leaves me with two variables in the first equation that I don't know, the absolute velocity of the air at the inlet and outlet. If the cross sectional area between the blades was constant (in say a tapered impeller), wouldn't the absolute velocity of the gas be the same at inlet and outlet? I know I can make variables "u" whatever I want by changing the internal and external diameter of the impeller until I get the desired exit gas velocity.
If there is another strategy to solve this problem, I'd like to know. If anyone has any insight to offer, I'd greatly appreciate it.
where
