Calculating Pressure for Oil Seed Pressing with 80 kW PTO Shaft
This discussion focuses on calculating the pressure generated by an 80 kW PTO shaft for oil seed pressing using a 4-inch diameter piston. The user, Paulwh, seeks to understand how to convert rotational power into pressure, applying the principles of first-class levers. Through calculations, he determines that with 80 kW equating to approximately 59004.97 ft lbf, the resulting pressure on the piston can reach 4695 psi, assuming a direct crank mechanism without considering linkage effects.
  • Understanding of PTO (Power Take Off) mechanics
  • Basic principles of physics, specifically force and pressure calculations
  • Knowledge of hydraulic systems and piston mechanics
  • Familiarity with units of measurement, particularly Newtons and psi
  • Research the mechanics of first-class levers in hydraulic systems
  • Explore advanced calculations for hydraulic pressure using different lever lengths
  • Learn about the design and efficiency of crank mechanisms in hydraulic applications
  • Investigate the impact of linkage systems on pressure generation in hydraulic presses
Farmers, mechanical engineers, and anyone involved in designing or optimizing hydraulic pressing systems for oil seed extraction.
paulwh
hi there,
i need some advice please.
I am a farmer that wants to press some oil seed rape. i have a tractor that produces 80 kw of power at its pto shaft (Power take off) and i want to use this rotational power to produce a reciprocating motion eg back and forth motion. The pto shaft has two speeds approx 500rpm and 1000rpm
I have attatched a picture to try and show what i am trying to achieve.
What i would like to know is how i go about calculating the pressure at the piston.
I have spent many hours trawling the net trying to find the answers and calculations but as yet havent.
I am using the principle of first class levers.
I know pressure is force divided by area (approx 4" diameter piston). And force is mass x acceleration. (what mass should i be using? what in this context is acceleration?)
But how do i get 80kw of rotation to convert to a given pressure in the cylinder.
as yet i don't know the ideal pressure figure i require to press the oil but i want to try different lever lengths to give me different pressures. and knowing how to calculate it would be ideal.
Thank you for taking the time to read this and hopefully someone will be able to help
Paulwh
This link may be able to help you out:
http://www.ulb.ac.be/sma/testcenter/Test/solve/basics/work/work.html
thanks minger i am working my way through it.
Am i right in assuming that the si unit of force is Newton metres.
watts = power
1 watt = 1 Newton meter per second. (force)
therefore 80 killowats = 80000 Newton meter / second (Nm/s)
80000 Nm/s = 59004.97 ft lbf
If pressure = F/A F= 59004.97ft lbf A= (4" rad ram) 12.566" sq
59004.97/ 12.566 = 4695 psi
So if i forget about the linkage multiplication effect and just use a straight crank type mechanism i should in theory be able to generate 4695psi on a 4" ram. (i am trying to keep it basic to get my head around the topic i realize there is then calculations based on the link minger qutoed)
Thanks for the help
Paulwh
11K
  • · Replies 34 ·
9K
  • · Replies 39 ·
15K
21K
