Calculating Primary Ionizations of Cosmic Muons in a Detector
  • Context: Graduate
  • Thread starter Thread starter Blidaru Bogdan
    Detector Muons
The discussion revolves around calculating the number of primary ionizations caused by cosmic muons in a MicroMEGAS detector filled with an Ar:CO2 gas mixture. Participants explore the theoretical framework, energy loss mechanisms, and practical considerations for measuring ionizations in a laboratory setting.
  • One participant describes the setup of the MicroMEGAS detector and the expected energy loss of a cosmic muon using the Bethe-Bloch formula.
  • Another participant suggests needing the average energy loss per ionization event in the gas mixture to proceed with calculations.
  • Participants discuss the number of primary electron pairs produced per cm and the average energy required for ionization, raising questions about the consistency of these values with the Bethe-Bloch approximation.
  • There is a calculation presented that indicates a discrepancy between expected energy loss and calculated ionization energy, prompting further inquiry into the reliability of the data sources used.
  • One participant expresses uncertainty about how to determine the number of primary ionizations from the total energy loss and the path length of the muon.
  • Another participant mentions the challenge of distinguishing between background events and the muon event, especially with a single detector setup.
  • There is a reference to using the Magboltz program for gas property identification, indicating a potential tool for further exploration.
Participants express differing views on the reliability of various data sources and calculations. There is no consensus on how to accurately calculate the number of primary ionizations, and multiple competing approaches and uncertainties remain throughout the discussion.
Limitations include potential discrepancies in temperature, pressure, and gas composition affecting the calculations, as well as the challenge of estimating values without comprehensive data on the gas mixture.
Blidaru Bogdan
I am currently studying the MicroMEGAS detector principle. Ionizing particles traverse the space of around 6 mm of Ar:Co2 mixture in the detector (10x10cm2 x 6mm) like in the picture below. A cosmic muon (4GeV) enters this space and ionizes along its path. I assume the longest path it can take (probabilistic) is alongside opposing diagonals of the rectangular parallelipiped (aprox. 142 mm) and the shortest is downstream (6mm).
Such a particle (minimum ionizing particle) loses energy following Bethe-Bloch formula at a rate of -dE/dx = 2 MeV/ (g/cm2). The density of the mix of Ar:CO2 is aprox. 1.7 kg/m3. This being said, a cosmic muon can deposit in 6mm and 142 mm or Ar:CO2 (-dE/dx * rho * x) 2.051 keV, respectively 48.536 keV.
It is normal that alongside its path, the muon ionizes in different points. My difficulty arises now assessing the number of such points (probabilistic). Given the above values of travel distances and energy values (and if possible given the configuration of the detector - that has a drift region where just a few primary ionizations occur, and an amplification region 40 kV/cm where electrons form avalanches), how can I calculate how many primary ionizations occur along the path of the cosmic muon?
And how can I be sure that the muon I am observing is a singular event at that particular time of the observation? (given the flux of about 1 cosmic muon per square centimeter per minute)
Thank you very much!
You'll need the average energy loss per ionization event in your gas mixture, probably a value to look up.
Travel distances from 6 to ~10 mm will be far more common than longer ones, especially if your detector is horizontal.
How good is your timing? Do you have a second detector layer to veto radioactive decays in the detector? You can never be 100% sure, but with good timing and a second detector also seeing the event at the same time and at the right place your background becomes negligible.
The only values I could found about the mixture are as follows:
The number of primary electron pairs per cm: 25.42
The total number of electron-ion pairs per cm: 93.7
Excitation energy: 11.6 eV
Ionization energy: 15.7 eV
Average energy required to produce electron-ion pairs: 26 eV
Now, I know the muon deposits in 6 mm a total of 2.051 keV. How can I distinguish from this total energy loss, the energy of the primary ionizations and their number?
Regarding the timing, I have just a configuration of just one horizontal detector. I am still only modelling it. In a laboratory setup, I cannot acquire another detector, so I am to rely on laboratory instrumentation.
26 eV/pair * 93.7 pairs/cm * 6 mm = 1460 eV, so the numbers don't match. Do they refer to the same temperature, pressure and gas composition? If yes, they are probably more reliable than the Bethe-Bloch approximation.
You have the number of electron ion pairs per length, and the length, that is everything you need (if the numbers apply here).
Then background radioactivity will be a large problem, much more than two muons hitting the same spot at the same time.
You can look at the hits and their arrival time at the individual detector components if the time resolution allows that.
The data I calculated was extracted from different sources treating minimum ionizing particles that revolve around 2 MeV/(g/cm2). Seems I was off. The latest reliable source I found (Atomic Data and Nuclear Data Tables, Vol. 76, No. 2, July 2001) states that this energy is more like 1.54 MeV/(g/cm2), which would lead to 1.613 keV being lost.
That would amount to about 60 ionizations along the path.
I was curious if without that data provided there was any way to know those numbers. Any idea?
Which numbers with data from where?
I got data regarding : the number of primary electron pairs per cm, excitation energy, the values in that post from Atomic Data and Nuclear Data Tables, Vol. 76, No. 2, July 2001.
If I only possessed my initial energy (4GeV), the energy loss inside (around 2 keV) and the path (6mm) is there any theoretical way to find out the number of primary ionizations along the path of the particle :)?
I tried to work with Loschmidt's number, a diameter for interaction with other particles and ionizing potential for Ar and amounted to 300 keV which is way off.
I am not sure which track to follow as they all lead to different results. If the results were in the range of an order of magnitude it would be a good start, but I'm way off :).
Not with some information about the gas. And estimating those values with a simulation is probably very hard and way beyond the scope of your project. Take the values from the database. You should get consistent results with them.
You are right! Thanks for the insight!
I am currently trying the Magboltz program developed at CERN for identifying properties of gases.
Seems it does the job. If anyone else is interested they should check it out.
  • · Replies 0 ·
9K
  • · Replies 24 ·
25K
