Calculating Probability using the Poisson Distribution
35 replies · 7K views
sol59
On average, 2 students per hour come into the class. What is the probability that the time between two consecutive arrivals is in the interval <10 minutes; 50 minutes>.
p(k)=P(Y=k)=((lambda*t)k*(e-lambda*t)/k!
I've tried using the Poisson distribution with k=2 t=40/60=2/3 and lambda=4/3 but the result is wrong. Thanks for helping!
Try to justify those parameters.
In the equation you quote, how would you describe the meanings of k and λ?
I think k is number of events that can happen in selected time unit...two student arrivals in this case and λ is average number of events that can happen in an hour...is it 2 as well? I'm not sure.
Yes, λ here is 2 per hour.
But the equation you quote is not suited to the task, directly. It gives you the probability of a specific number of arrivals in a specific period of time. You want the probability that the time between a particular pair of consecutive arrivals is in some range.
You might as well suppose that the first of the two arrivals has just occurred. How can you rephrase the question a bit more simply?
I could use the Exponential distribution and determine the time of waiting for another arrival?
2*e(-2*t) where t=2/3?
No, you need to do some more thinking before trying to plug numbers into an equation.
Suppose that one student has just arrived. Rephrase the question in terms of a single arrival.
Well I need to find out if the time of waiting for arrival of the second student is in the interval <= 50 minutes. And the arrival of the first student has to be in the interval >= 10 minutes.
No, we can start the clock when the first student arrives. What are the constraints on the arrival time of the next student?
The second student has to come 40 minutes later at most after the first student.
No, that is not what the question says. Read it again:
Edit: maybe the word interval is confusing you. Here it just means a range of values: the time between two consecutive arrivals is in the range from 10 minutes to 50 minutes.
The second student has to come in the fiftieth minute at the latest?
haruspex said:
And the earliest?
The fiftieth minute minus the time when the first student came?
No, what is the earliest, after the first student, that the second student can arrive (to fit in the given window)?
Let's make it more concrete. Say the first student arrives at 9am. Between what two times is the second student to arrive for the gap between them to be from 10 to 50 minutes?
It's late here... off to bed.
9:10-9:50?
haruspex said:
Right.
So how many students arrive between 9 and 9:10?
0 (and between 9:50-10 too)...but I still don't know how to solve it.
sol59 said:
Right. Using your equation, what is the probability of that?
No. We might come back to that later.
How many students arrive between 9:10 and 9:50?
9:00-9:10 P(Y=0)=((2*1/6)0*(e-1/3))/0!=0.716
9:10-9:50 1 student P(Y=1)=((2*2/3)1*(e-4/3)/1!=0.351
We are getting there. But why exactly one student between 9:10 and 9:50? What goes wrong if two arrive?
I don't know:( P(Y=2)=0.234 but I don't understand what to do with it
For the moment, just try to answer my question. If no student arrives between 9 and 9:10, but two arrive between 9:10 and 9:50, does that meet the requirement that the time from the 9am arrival to the next arrival lies between 10 minutes and 50 minutes?
What if 3 arrive between 9:10 and 9:50? Four? ...
I think it meets that requirement but it is also said that 2 students per hour come into the class.
Right. So is there any limit on the number that can arrive between 9:10 and 9:50?
That's just an average rate. Poisson processes have no memory. In each short period of time dt, the probability of an arrival is λdt. If one does arrive, the probability is still λdt for the next period dt. In principle, a million could arrive in a single minute (ok, this is an idealised view), but the probability would be vanishingly small.
That's interesting...so there is an unlimited number of students that can arrive in that interval. But how to express it mathematically?
What number of arrivals between 9:10 and 9:50 does not meet the condition?
0?
sol59 said:
0?
Right.
So we have boiled it down to two requirements:
No arrivals in (9:00, 9:10), and
Not (no arrivals in (9:10, 9:50))
Can you figure out the probability of the second of those, and combine it with the probability you already found for the first?
haruspex said:
Right.
The probability of no arrivals in (9:10, 9:50) is P(Y=0)=e-4/3=0.264
Thank you for your patience.
