Calculating Projector Focal Length with SXGA & Screen Dimensions
This discussion focuses on calculating the focal length range of a projector with SXGA resolution, specifically when the projector is positioned between 4 to 12 meters from the screen. Key equations mentioned include the lens formula (1/f = 1/v + 1/u) and the magnification formula (M = v/u), which are essential for determining the focal length based on screen dimensions and display size. Participants emphasized the importance of knowing the horizontal dimension of the display to accurately compute magnification and subsequently the focal length.
  • Understanding of lens formulas, specifically 1/f = 1/v + 1/u
  • Knowledge of magnification calculations, including M = v/u
  • Familiarity with projector specifications, particularly SXGA resolution
  • Ability to derive dimensions from diagonal measurements of displays
  • Research how to calculate horizontal dimensions from diagonal measurements in projectors
  • Explore the relationship between numerical aperture and focal length in optics
  • Learn about different projector resolutions and their impact on focal length calculations
  • Investigate practical applications of lens formulas in real-world projector setups
This discussion is beneficial for optical engineers, projector technicians, and anyone involved in calculating projector specifications and setups, particularly in educational or professional environments where precise image projection is critical.
questions_uk
Hi. It asks to calculate the focal length range of a projector of square pixel SXGA is from 4 to 12 m from the screen. It gives the diagonal size of the display (in mm) as well as the horizontal size (in m). The thing that am not sure about is how the focal length would be calculated with the screen dimensions and whether info about square pixels and SXGA would be required. I assume the range means to calculate the focal length at 12 then at 4 and take these values away from one another?
Any help is appreciated.
Thanks.
I am guessing you'll need to take the magnification into account, which means you would need to know the size of the screen as well.
The equation for magnification, and other stuff about lenses, is here:
https://www.physicsforums.com/library.php?do=view_item&itemid=148
The question sounds a little weird, since the focal length of a lens is not adjustable.
Thanks for the reply. Interestingly enough I also wondered whether the magnification would be taken into the account, as magnification is included in the notes. What was a bit weird was how it gave the diagonal dimension of the display and the horizontal dimension of the screen?
Okay. Looks like you'll have to figure out the horizontal dimension of the display, in order to get the magnification.
That's what I thought, and then compare the display with the screen. However, the magnification depends on U and V which I think are the lengths from the display to the lens and from the lens to the screen.
Yes, that's right.
It would be useful, if you haven't done so already, to list the equations that are relevant to solving this problem.
Redbelly98 said:
Yes, that's right.
Hi. Some of the equations I've got include:
1 / f = 1 / v + 1 / u
And M = v / u
Also am not sure if this is related to it but
Numerical Aperture / F number
N = F / D
Thanks!
Okay, good. I'm thinking the numerical aperture and lens diameter won't come into play here, at least I haven't seen anything yet that would relate to them. (Of course, I also haven't seen the actual problem statement either.)
The magnification equation and "1/f = ..." are important here.
Something that is pretty much assumed, but maybe not obvious to students, is that M is also, by definition,
M = (width of screen) / (width of display)​
See if you can use that, plus the "1/f = ..." and magnification equations you listed, to solve the problem.
Thanks for your help! I basically used the other magnification rule you gave and assumed a value for the horizontal dimension.
This could then be be used with M = v / u thus calculating u as v and M are already known and obtaining a v value. With the u and f values I used 1 / f = 1 / u + 1 / v to obtain the focal length at 4 and 12 m. Then obtained the difference between these two values to obtain the range.
But yeah I did assume a value for the horizontal component. It gives the diagonal dimensions.
Thanks!
Sounds like you pretty much have it then.
If you knew the width/height ratio for the display, you could figure out the horizontal dimension rather than just "assume a value".
Thanks for your help. I used the resolution of the dosplay to work out the horizontal dimensions of it.
