Calculating q2 and q3 on a Conducting Shell?
The discussion revolves around a problem involving an insulating sphere with a uniformly distributed charge and a surrounding conducting shell. Participants are tasked with determining the charges on the inner and outer surfaces of the shell, denoted as q2 and q3, given the total charge on the shell.
  • Participants explore the application of Gauss's law to deduce relationships between the charges. Questions arise regarding the implications of the conducting shell and the electric field within it. Some express uncertainty about how to apply Gauss's law without knowing certain variables.
The discussion is active, with participants engaging in reasoning about the charges involved and the implications of Gauss's law. Some guidance has been offered regarding the nature of the electric field within a conductor and the relationship between the charges. Multiple interpretations of the problem are being explored.
Participants note the challenge of working with incomplete information and the need to clarify definitions, particularly regarding the conducting shell and its properties. The total charge on the shell is specified, but the relationship between the charges remains a point of inquiry.
dragonrider
Consider an insulating sphere with radius of 7 cm. A charge of 13.8561 µC is uniformly distributed throughout this sphere. It is surrounded by a conducting shell. Denote the charge on the inner surface of the shell to be q2 and the charge on the outer surface of the shell to be q3. The total charge q on the shell is of 64.0681 µC.
http://img381.imageshack.us/img381/5829/problem2jy1.th.gif
Find q2 and q3? Answer in units of µC
For this problem I am not sure where to start because I only have one radius.
https://www.physicsforums.com/attachments/14744
You don't even need that radius. See what you can deduce by putting Gaussian surfaces in various places and applying Gauss's law. Hint: Take advantage of the fact that it's a conducting shell.
I am not sure what you mean by conducting shell. Because isn't E = -q/(4*π*ε0*r2).
An electrical conductor--like a metal. Hint: What's the field within a conductor?
I know that the field within a conductor is zero. But I need the charge of the inner an outer surface of the shell.
Use Gauss's law!
Yes if I apply Gauss' Law E = q/(4*π*ε0*r2) but I don't know both E and r. and if I use E = 0 wouldn't that make q2 = 0
dragonrider said:
since the E = 0 inside does q2 = 0?
What does Gauss's law tell you? (Use a Gaussian surface inside the conducting shell, where E = 0.)
I used E = 0 but then q2 = 0.
The q in Gauss's law stands for the total charge. (q2 is just the charge on the inside of the shell. You'll use the total charge to determine q2.)
So how do I apply Gauss Law to find q2 and q3 without knowing either E nor r?
P.S.
I know I am asking very basic stuff but I just learned the concept and I haven't fully understand on how to use Gauss Law properly yet.
But you do know E inside the conducting shell. So what does that tell you about the total charge contained within a Gaussian surface inside that shell? (Hint: q2 is just one of the charges inside that surface. What's the other?)
So the charge contained within the Gaussian surface = q1
Nope. (But that is one of the charges within the Gaussian surface.) Draw a diagram showing where the Gaussian surface goes. The problem only defines three charges: q1, q2, and q3. Which are inside the Gaussian surface? Which are outside?
Inside are q1 and q2. Outside are q3
Yes! So what's the total charge inside the surface? What must it equal from Gauss's law?
So [(q1+q2) /(4*π*ε0*r2)] = [q3/(4*π*ε0*r2)]
Does q2 + q3 = 64.0681 µC
:confused:
Answer these questions:
(1) What's the total charge within the Gaussian surface in terms of q1, q2, and q3?
(2) What does E equal at all points on the Gaussian surface?
(3) What does Gauss's law tell you about the total charge?
(4) Write a simple equation expressing the above.
q1 = -q2
q3 = 2*q1
I should have said:
:confused:
Good. This doesn't follow from Gauss's law, but from the fact that you were given the total charge of the shell.
dragonrider said:
q1 = -q2
Yes! This does follow from Gauss's law, since Qtotal = 0 = q1 + q2.
q3 = 2*q1
Where does this come from?
I got it thank you very much for helping me.
13K
15K
