Calculating Radius of Curvature for Upright Image Mirror
  • Thread starter Thread starter DDRchick
    Curvature Radius
The discussion revolves around calculating the radius of curvature for a mirror that produces an upright image with a specified magnification and distance from an object. The subject area includes optics and mirror equations.
  • Mixed
  • Participants explore various methods to calculate the radius of curvature using mirror and magnification formulas. There is a focus on the interpretation of the problem statement, particularly regarding the distances involved and the signs used in the equations.
Multiple interpretations of the problem are being explored, particularly concerning the meaning of the distances and the application of signs in the formulas. Some participants have provided guidance on potential errors in the original poster's approach, suggesting adjustments to the calculations.
There is uncertainty regarding the correct interpretation of the distances in the problem, as well as the application of signs in the magnification formula. The original poster expresses frustration with repeated incorrect results despite following suggested approaches.
DDRchick
A production line inspector wants a mirror that produces an upright image within magnification of 7.9 when it is located 10.0 mm from a machine part.
What is its radius of curvature?
I used:
r/2 = f
1/f=(1/do) + or - (1/di)
m=di/do
first i did 7.9=10/do
then i found that do=1.27mm
So then i did 1/f=1/1.27+1/10
I got f=1.3
Then i multiplied that by 2
(r/2)=f
So then i got 2.6
I tried -2.6 for the heck of it
and then i did it all again except i did:
1/f=1/1.27-1/10
and calculated it all out and it was still wrong.
Even when it was negative.
Argh. Help? =( Because i have 2 more like this. x.x
Hi DDRchick,
The question here is using the word "it" which can often cause trouble (and I think might be leading to a mistake in your work). Is it referring to the mirror's distance from the object, or the image's distance (because I've seen problems with the meaning both ways). From the wording though, I think it means that the mirror is 10mm from the object.
I used:
r/2 = f
I don't think there would ever be a negative sign in this formula (though sometimes do or di can be negative values).
m=di/do
This formula need a minus sign:
[tex] m=-\ \frac{d_i}{d_o}[/tex]
d_i is the image distance (distance from image to mirror); I don't think that's what the 10mm refers to in the problem statement. I think when you change these three things you'll get the right answer (because your basic approach looks right to me).
Ugh It's still wrong. :/
Crap bucket.
di/10=7.9
di=79
1/f=1/79+1/10
f=8.88
r/2=8.88
8.88(2) = 17.76
I tried it with a negative sign too just for kicks, that was marked wrong also.
Crap bucket.
di/10=7.9
Remember that I mentioned above that this formula needs a minus sign. So di will be -79mm.
di=79
1/f=1/79+1/10
f=8.88
r/2=8.88
8.88(2) = 17.76
Do you mean you just put in -17.76, or that you used the minus sign in the magnification formula? If you use di= -79mm, I believe the rest of your procedure is fine.
I mean i just put in -17.76...
Garr.
Well thanks for your help, it was due a day ago unfortunately, but i survived aha.
  • · Replies 16 ·
