Calculating Resistance of Z for 6V Identical Lamps in Parallel Circuit
  • Thread starter Thread starter nobb
    Circuits
The discussion revolves around calculating the resistance of a series resistor Z in a circuit with identical lamps connected in parallel, powered by a 12V source. The lamps are rated for 6V operation, and the problem involves understanding the voltage distribution in the circuit.
  • Participants explore the relationship between the total voltage, the voltage across the lamps, and the series resistor. Questions arise regarding the equivalent resistance of the lamps and how voltage is divided in series circuits.
There is an ongoing exploration of the circuit's behavior, with some participants suggesting algebraic approaches to find the resistance Z. Multiple interpretations of the circuit setup and the number of lamps are being considered, but no consensus has been reached.
Participants note the lack of information regarding the number of lamps in the circuit, which affects their ability to fully analyze the problem. The discussion is framed within the constraints of homework rules, focusing on reasoning rather than providing direct solutions.
nobb
The identical lamps in the circuit (attachment) each have a resistance R at their rated voltage of 6V. The lamps are to be run in parallel with each other using a 12V source and a series resistor Z in the circuit as shown. If the lamps are to operate at their rated voltage, what must be the resistance of Z?
A. R/2
B. R
C. 2R
D. Zero
Any ideas?
The set of parallel resistors and resistor Z are in series. The net voltage in the circuit is 12V. If each lamp operates at 6V, how does their equivalent resistor's voltage compare? How do series resistors handle voltage in circuits?
I can't fully guess how many lamps are in nobb's circuit until attachment is approved. Given the solution possibities, I am guessing two lamps.
It sounds like a voltage divider arrangement, with the output voltage already known (6V). After combining all the parallel resistances (bulbs), you just need to do some algebra to solve for Z.
I know I have to do some algebra to find some sort of ratio. My problem is that I have no idea where to start.
When the electrons leave the negative terminal, they have to go through a 12V total drop. Which means once theyve gone through the whole circuit, theyve dropped 12 V. So The voltage drop through Z plus the voltage drop through the parallel equivalent resistor is 12V
Z + P_eq = 12
Can you find P_eq? What do you know about the two?
It should be even easier when you look at the fact that you have 12 volts, you want to have 6 volts across the bulbs, and you know you therefore need to drop the other 6 volts across the resistor.
I was trying to have him realize that, but thanks for your input anywa.y
  • · Replies 21 ·
