Calculating Rotational Inertia (A Bit of Confusion)
The discussion centers on the calculation of rotational inertia and the confusion surrounding the application of the center of mass in rotational motion. It clarifies that while the center of mass can be treated as a point for translational motion, this does not hold for rotational motion, where the distribution of mass affects inertia. The conversation highlights that when a rod swings around a pivot, its moment of inertia must account for both the rotation around the pivot and the rotation about its center of mass. The correct total moment of inertia combines these two components, leading to the established formula of ML^2/3. Understanding these principles is essential for accurately calculating rotational inertia in various physical scenarios.
Lemniscates
Hey all,
Perhaps this is a bit stupid...
I'm familiar with the normal procedure of calculating rotational inertia (using integration, parallel axis theorem, etc.). However, I had a confusing thought: if the center of mass of a body is the point at which you can treat as all of the mass being concentrated there and also all the external forces, then why can't I say something like this:
If a uniform rod of length L is swinging around a pivot, and the center of mass of the rod is a distance L/2 away from the pivot, then why can't we treat that center of mass as the place where all the mass is concentrated and use the rotational inertia formula for a particle (MR^2) and subsequently get M(L/2)^2? I know it's ML^2/3, but what is the problem here?
Hello Lemniscates,
You have to be careful when you use qualitative statements such as: "the center of mass of a body is the point at which you can treat as all of the mass being concentrated there". In fact, this is only true for translational motion! If you follow the mathematical derivation of this statement, you will notice that one of the underlying assumptions is that the motion under consideration is translational. Therefore, it makes no sense and it is mathematically incorrect to apply this statement to a system undergoing rotational motion.
Zag
Ah. That's interesting. But what about problems involving physical pendulum calculations? From what I've read and have been taught, when you calculate the torque induced by gravity in a physical pendulum, you use the distance from the center of mass to the pivot as the length of the moment arm, essentially saying that all of the gravity acts at the center of mass (and is that not a use of the center of mass/external forces statement?). So how is that justified if the statement about centers of mass can only be applied to bodies in translational motion?
It's like swinging a sledgehammer: if you grasp the end of the handle and swing the hammer, it takes a certain amount of effort to swing the head. However, if you turn the hammer around and swing the handle by grasping the head, it takes less effort than the first instance. The c.g. of the hammer has not changed, but its location from the axis of rotation has. Since you are not swinging the heavy head in as large a radius of arc in the second instance as in the first instance, it takes less effort.
Lemniscates said:
Hey all,
In effect, you somewhat can. You are correctly accounting for the moment of inertia due to the rotation of the center of mass around the pivot, but in that motion, the rod is also rotating about its center of mass. Your formulation would be correct if the rod were somehow maintaining its orientation while revolving around the pivot (I'm sure such an apparatus could be constructed). However, since the rod is rotating, you can do the following.
You can consider your situation as the superposition of two situations:
1) The rotation of the center of mass of the rod around the pivot (which, as you surmised, gives ML2/4)
2) The rotation of the rod about its own center of mass (which gives a moment of inertia of ML2/12)
If you sum these two factors, you get that the total effective moment of inertia is ML2/4 + ML2/12 = 4ML2/12 = ML2/3. This is a useful way to find the overall moment of inertia of a system, since all you need to know is the moment of inertia of the individual parts of the system about their own centers of mass, and the distance each center of mass is from the pivot of the overall system. This is known as the Parallel Axis Theorem
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
