Calculating Rotations and Slip in an Asynchronous Motor
  • Context: Engineering
  • Thread starter Thread starter Marketgirl
    Asynchronous Motor
4 replies · 2K views
Marketgirl
number of pole pairs p =2
line frequency f=50hz
number of rotations n=1250 1/min
question is number of rotations of the rotary magnetic field (1/min units)
the slip of the machine(s)
the frequency of the rotor current ?
please help me to solve this kind of problems i have like 5 more questions which is smilar to this one so i can learn how to solve others thank you from now good luck at your exams :)
If you have the line frequency and the number of pole pairs, you can get the rotation of the stator Ns by using
[tex]N_s = \frac{120f}{p}[/tex]
where f is the line frequency and p is the number of poles.
How is slip defined?
s = Ns-Nr/Ns Ns is stator electrical speed, and Nr is rotor mechanical speed. thank you for your helps sir.
Right, so using the formula I gave you above, you can get Ns. They gave you the value of Nr, so can you get the slip?
yes sir your help was enough, i wish you best of luck and thank you so much.
