Calculating Self Capacitance of an Isolated Sphere
35 replies · 7K views · last reply
Saitama
(see attachment)
The self capacitance of an isolated sphere is ##4\pi \epsilon_o R## where R is the radius of sphere but I am not sure how to begin on this one.
Any help is appreciated. Thanks!
  • Text problem: three concentric metallic spheres with radii R1 = 10cm, R2 = 30cm, R3 = 40cm; inner and outer spheres grounded; Q = C_self V; find C_self in Farads for the middle sphere.
  • Diagram of three concentric spheres drawn in perspective: a small green sphere labeled R1, a blue hemispherical shell labeled R2, and a large orange sphere labeled R3, with dashed back arcs showing the equators.
I do not think it is correct to talk about self-capacitance here. Self-capacitance involves a potential difference with a infinitely far away object, while in this case you are given two other objects at finite distances. I think you could treat the setup as two parallel capacitors, formed by spheres 1-2 and 2-3.
Add some charge Q onto the middle sphere, find the electric field and potential in the regions between the spheres. You know that the potential is zero on the inner and outer sphere.
ehild
But how will that help in finding the self capacitance of the middle sphere?
Electric field outside the sphere is given by ##kQ/r^2## and inside it is zero but I am still clueless. :(
You have ignored what I wrote earlier.
Can you please shed some more light on this? I have checked your post more than 10 times but I still can't see what I have missed.
You are explicitly given potentials between three objects, with finite distances from one another. Self-capacitance, however, is defined in terms of the potential difference with an infinite-radius sphere. You can't have it both ways.
Do you mean that the given question is wrong then?
Continuing ehild's suggestion, if I give a charge to the middle sphere, will there be any charges induced on the other spheres?
Why should it be wrong?
Why not?
ehild
ehild said:
Why not?
ehild
Please see the attachment if I have mentioned the induced charges properly (I think they are wrong).
If they are right, should I calculate the potential at the surface of innermost and outermost spheres and set them equal to zero?
I did these types of problems in the past but now I have completely forgotten how to do them. :(
  • Concentric circles diagram of three nested spherical shells in cross-section, labelled -q1 on the innermost shell, q1 and Q-q1 on the middle shell, -(Q-q1) and (Q-q1) on the outer shell; two ground symbols connect to the innermost and outermost shells.
Concentric circle diagram of three spherical shells with charge labels: inner sphere -q1, middle shell q1 on its inner surface and Q-q1 on its outer, outer shell -(Q-q1) on its inner surface and (Q-q1) on its outer surface; two ground symbols connect to the inner and outer shells.
That looks good to me, except for the charge on the outside of the outer sphere.
Yes, I too think that its wrong that's why I wrote in brackets that they look wrong to me. Any hint about what should be those charges?
that is zero outside.
ehild
The potential of the sphere is zero, so the electric field exterior to the sphere must be zero.
The charges mentioned on the inner surface of outermost sphere are right?
When I calculate the potential, do I need to add potential of both outer and inner surfaces of each sphere? :confused:
Yes. The charge on the inner surface are exactly opposite the charge on the outer surface of the middle shell.
No. (Assuming I understand your question correctly.)
The potential difference between the middle & outer shells should give you the charge, Q - q1 .
The potential difference between the inner & middle shells should give you the charge, q1 .
Apply Gauss's Law in the regions between the spheres. Integrate the electric field to get the potential difference between the middle sphere and the inner one, and also between the middle sphere and the outer one. They must be equal.
ehild
ehild
The potential difference between the innermost and the middle sphere is:
[tex]kq_1 \left(\frac{1}{R_1}-\frac{1}{R_2}\right)[/tex]
The potential difference between the middle sphere and the outermost sphere is:
[tex]k(Q-q_1)\left(\frac{1}{R_3}-\frac{1}{R_2}\right)[/tex]
Have I calculated the potential difference right?
ehild said:
Check the sign of the second one.
I expected you to say that but I couldn't find the mistake in my working.
Potential at the surface of outer sphere is ##k(Q-q_1)/R_3## and potential at the surface of middle sphere is ##k(Q-q_1)/R_2##, therefore the potential difference is [tex]k(Q-q_1)\left(\frac{1}{R_3}-\frac{1}{R_2}\right)[/tex].
:confused:
The potential of both the inner and the outer sphere is zero (with respect to infinity). Assuming positive Q, the potential of the middle sphere is positive. What is the potential of the middle sphere?
You can not write the potential in this problem as kQ/r, as it is zero both at r=R1 and r=R3.
Do what I said about the electric field.
ehild
The electric field between the middle sphere and the outermost sphere is ##k(Q-q_1)/r^2##.
[tex]V(R_3)-V(R_2)=-\int_{R_2}^{R_3} \vec{E} \cdot \vec{dr}[/tex]
##V(R_3)=0##. Hence
[tex]V(R_2)=k(Q-q_1)\left(\frac{1}{R_2}-\frac{1}{R_3}\right)[/tex]
Is this right?
It is right. Now express V(R2) using the electric field between the innermost sphere and the middle one.
[tex]V(R_2)-V(R_1)=-\int_{R_1}^{R_2} \frac{-kQ}{r^2} dr[/tex]
Solving
[tex]V(R_2)=kq_1 \left(\frac{1}{R_1}-\frac{1}{R_2}\right)[/tex]
Equating both the expressions
[tex](Q-q_1)\left(\frac{1}{R_2}-\frac{1}{R_3}\right)=q_1 \left(\frac{1}{R_1}-\frac{1}{R_2}\right)[/tex]
Solving,
[tex]q_1=\frac{Q\left(\frac{1}{R_2}-\frac{1}{R_3}\right)}{\left(\frac{1}{R_1}-\frac{1}{R_3}\right)}[/tex]
Do I need to use ##Q-q_1## and the potential at the surface of the middle sphere in the equation ##Q=C_{self}V##?
You have q1, and can plug that into any equation for V(R2). The charge of the middle sphere is Q. q1 and Q-q1 are the surface charges.
ehild
ehild
[tex]C_{self}=\frac{Q}{V(R_2)}[/tex]
[tex]=\frac{Q}{V(R_2)}=\frac{Q}{kq_1 \left(\frac{1}{R_1}-\frac{1}{R_2}\right)}[/tex]
Should I substitute the value of ##q_1## in this expression?
ehild said:
Yes. It is not THAT terrible:biggrin:
I plugged in the values and got 13.5*10^8 but this is wrong. :(
What is your formula for Cself? Have you plugged in k?
I posted it above in one of my post. :-)
Oops, I guess I realized my mistake.
