Calculating Sound Level Intensity with Multiple Jet Engines
  • Thread starter Thread starter mortho
    Intensity Sound
The discussion revolves around calculating sound level intensity related to jet engines, specifically how the sound level changes when multiple engines are shut down. The original poster presents a scenario involving four jet engines producing a sound level intensity of 114 dB and seeks to determine the intensity when only one engine remains operational.
  • Participants discuss the use of the relative intensity formula and express confusion about the next steps after calculating intensity. Some participants question the assumptions regarding the reference intensity and the implications of shutting down engines.
There is an ongoing exchange of ideas, with some participants providing guidance on how to approach the problem. Others are exploring different scenarios, such as varying initial sound levels, and questioning the reference intensity value used in calculations.
Participants mention the reference intensity of 1e-12 w/m2 as the threshold of human hearing, which is a point of confusion for some. There is also a mention of differing initial sound levels (114 dB vs. 121 dB) affecting the calculations.
mortho
A person standing a certain distance from an airplane with four equally noisy jet engines is feeling a sound level intensity bordering on pain, 114 dB. What sound level intensity would this person experience if the captain shut down all but one engine?
I have no idea how to do this problem. I thought this was relative intensity so i plugged it into the formula and found intensity. Now I'm not sure what to do. Thanks!
It is a relative intensity problem. Which formula did you use? You were supposed to enter that into Part 2 of the posting template.
Show us what you did. That was supposed to go into Part 3 of the posting template.
Yeah, i was in a rush when i posted that because my computer's being repaired and I'm at the library and time was running out. Here's my work
I used relative intensity=10log (I/Io)
114=10log(I/1e-12) and got 0.251 w/m2 for I. I do not know what to do after this.
OK, you have the value for I, divide by four and calculate the new sound level intensity.
Is it 108 Hz?
i just submitted and it was correct. THanks for your help :)
No problem.
The thing to realize is, you had the value for the power / m^2 at whatever arbitrary distance from the plane, then 3/4 of the engines were shut down, so you automatically know the new power / m^2 at this arbitrary distance.
I have the same problem. Except instead of 114 dB it's 121 dB. I do not understand where the 1e-12 came from. Can someone tell me please?
Also, here is what I have done so far:
121=10log(I/Io)
121/10=log(I/Io)
10^12.1=I/Io
Now I do not know what to do... I am stuck there since I have no clue to what Io is and we're trying to solve for I- two variables one equation...
Please Help.
Io = 10-12 w/m2
This is the lowest threshold of human hearing.
So the ratio of the sound intensity to that is 121/10 or
I = 121dB can also be written as 1012.1*10-12 w/m2
I did that and I got an answer of .315 dB
I need the answer to be in dB to submit. Can you tell me what I am doing wrong here?
Perhaps you should show your work. And maybe even what the problem is, because, if it is the same as the OP here where 3 jet engines cut out, you won't be getting .315 dB, if you calculated it correctly.
