Calculating Sound Level Intensity with Multiple Jet Engines
  • Thread starter Thread starter mortho
    Intensity Sound
10 replies · 20K views · last reply
mortho
A person standing a certain distance from an airplane with four equally noisy jet engines is feeling a sound level intensity bordering on pain, 114 dB. What sound level intensity would this person experience if the captain shut down all but one engine?
I have no idea how to do this problem. I thought this was relative intensity so i plugged it into the formula and found intensity. Now I'm not sure what to do. Thanks!
It is a relative intensity problem. Which formula did you use? You were supposed to enter that into Part 2 of the posting template.
Show us what you did. That was supposed to go into Part 3 of the posting template.
Yeah, i was in a rush when i posted that because my computer's being repaired and I'm at the library and time was running out. Here's my work
I used relative intensity=10log (I/Io)
114=10log(I/1e-12) and got 0.251 w/m2 for I. I do not know what to do after this.
OK, you have the value for I, divide by four and calculate the new sound level intensity.
i just submitted and it was correct. THanks for your help :)
No problem.
The thing to realize is, you had the value for the power / m^2 at whatever arbitrary distance from the plane, then 3/4 of the engines were shut down, so you automatically know the new power / m^2 at this arbitrary distance.
I have the same problem. Except instead of 114 dB it's 121 dB. I do not understand where the 1e-12 came from. Can someone tell me please?
Also, here is what I have done so far:
121=10log(I/Io)
121/10=log(I/Io)
10^12.1=I/Io
Now I do not know what to do... I am stuck there since I have no clue to what Io is and we're trying to solve for I- two variables one equation...
Please Help.
Io = 10-12 w/m2
This is the lowest threshold of human hearing.
So the ratio of the sound intensity to that is 121/10 or
I = 121dB can also be written as 1012.1*10-12 w/m2
I did that and I got an answer of .315 dB
I need the answer to be in dB to submit. Can you tell me what I am doing wrong here?
Perhaps you should show your work. And maybe even what the problem is, because, if it is the same as the OP here where 3 jet engines cut out, you won't be getting .315 dB, if you calculated it correctly.
