Calculating Stokes's Theorem on a Triangular Contour
  • Thread starter EugP
    Theorem
11 replies · 4K views · last reply
EugP
For the vector field [tex]\bold{E} = \bold{ \hat x} (xy) - \bold{ \hat y} (x^2 + 2y^2)[/tex], calculate the following:
[tex]\oint \bold{E} \cdot d\bold{l}[/tex] around the triangular contour shown.
I don't have a scanner at the moment so I will explain the drawing. The picture is a right triangle. They show an x and y axis. From (0, 0), there is a line going to (1, 0), then from there it goes up to (1, 1), then a diagonal back to (0, 0).
I know how to approach it but I seem to be stuck. This is what I have so far:
I gave each coordinate a name: a (0, 0), b (1, 0), and c (1, 1).
[tex]\oint \bold{E} \cdot d\bold{l} = \oint_a^b \bold{E}_{ab} \cdot d\bold{l} + \oint_b^c \bold{E}_{bc} \cdot d\bold{l} + \oint_c^a \bold{E}_{ca} \cdot d\bold{l}[/tex]
At this point I'm stuck. Could someone please point me in the right direction?
Your confusion probably lies in that you don't know what [tex]\vec{dl}[/tex] is. For example, for the integral from a to b, [tex]\vec{dl_{1}}=\hat{x}dl[/tex], whereas b to c it becomes [tex]\vect{dl_{2}}=\hat{y}dl[/tex]. Just work out the dot products, which are especially easy for a to b and b to c since either x or y is constant.
Thanks for the quick reply. I have 2 questions:
1) Shouldn't the integral from a to b, be [tex]\oint_a^b \bold{E}_{ab} \cdot \hat x d\bold{l}[/tex] since ab is horizontal?
2) I'm not sure what to put for [tex]\bold{E}_{ab}[/tex]. Should it be the component that acts only in the direction of ab, in other words:
[tex]\oint_a^b \bold{ \hat x} (xy) \cdot \hat x d\bold{l}[/tex]
Am I in the right direction?
Yes whoops you are right about 1). I will change it. And 2) yes you are right. Don't forget that y is a constant.
Awsome. So now that I set it up, I have [tex]\oint_a^b xy d\bold{l}[/tex], but I don't know l, or am I missing something obvious?
Remember that a is (0,0) and b is (1,0). [tex]dl[/tex] is simply dx in that particular case. The only tricky part is going to be c to a, where you're going to have to express all components of dl in terms of one variable to integrate over.
If the path is along the positive x axis, you must use [tex]d \vec{l} = dx \vec{i}[/tex]
and so on.
In general, [tex]d\vec{l} = dx \vec{i} + dy \vec{j} + dz \vec{k}[/tex]
If you have a parametrized curve, you replace all the variables in terms of the parameter and the integral is only over one variable,
Since you titled this "Stokes Theorem", are you also going to integrate -2x-2y over the triangular region and show that they are the same?
Actually yes, and I'm stuck on that too.
Also, I thought I figured out how to finish the first part, but it's not working out.
Here's what I'm getting:
[tex]\oint \bold{E} \cdot d\bold{l} = \oint_0^1 xy dx + \oint_0^1 -x^2-2y^2 dy + \oint_c^a \bold{E}_{ca} \cdot d\bold{l}[/tex]
but I don't know what to do with the last term. And when I integrate the first two terms, I get
[tex]\frac{y}{2}-x^2-\frac{2}{3}[/tex]
which doesn't make sense, because the answer for the whole is -1. What should I do with the last term? Shouldn't it be:
[tex]\oint_0^1 (xy - x^2 +2y^2) dxdy[/tex]
this is a perfect question to use Green"s theorem. And the answer is -1. Stokes' theorem is just a generalized version of Green's th. and I don't see how that would be useful in this case. Also there is no need to do 3 integrations. Just convert the whole thing to a double integral using Green's theorem, integrate over the triangle and get -1
