Calculating Support Forces in Statics: Solving Equations for A and B
8 replies · 2K views
aaronfue
I've been trying to figure this out for 4 days now. I'm completely stumped. I've attached a picture of the diagram: http://postimage.org/image/t3d5i0l1v/
I found the force in F:
F = 25.04 lb ---> 16.92i + 18.46j
Now I need to find the support forces at A and B.
I'm not sure if this is right but I came up with the following equations:
I used the angle at the supports as 42°.
ƩFx=0= -Bx*cos42 - Ax*cos42 +16.92
ƩFy=0= - By*sin42 - Ay*sin42 +18.46
Then I thought about taking the moment about point A:
ƩMa=0=Fx*2 + Fy*9 - Bx*cos42 *(9) - Bysin42 *(8)
Then the moment about the other points F and B. A the end I got the following equations.
ƩFx (Eq. 1): (0.743)Ax + (0.743)Bx = 16.9
ƩFy (Eq. 2): (0.670)Ay + (0.743)By = 18.5
ƩMa (Eq. 3): (6.7)Bx + (5.63)By = -200
ƩMb (Eq. 4): (6.7)Ax - (5.63)Ay = 100
Now when I try to solve these equations my unknowns cancel out! What’s the deal!??
I'm sorry I didn't clarify the force, F.
The given information was: "The force F creates a 200 lb moment about point A and a 100 lb moment about point B. Calculate the force F." I created the equations to find the force using the geometry and points given in the diagram.
The question did not ask about the support forces but I want to figure them out just for knowledge.
I'm not sure why you are multiplying Bx, By, Ax, Ay by angles. The component of B in the x direction is Bx. The component of B in the y direction is By.
If B was your vector and B was the magnitude of the vector B then I could see Bx = B cos 42, By = B sin 42, etc. But you notation is shorthand for B = Bx i + By j
The coordinates for F are (4,3).
You're right aralbrec...I usually use them as a reference for which axis I'm working with. I completely forgot about that! Thanks for the reminder!
from the vertical
your error here has already been addressed
Since the support at B is a roller, it can only support forces perpendicular to AB; so in your above equation, take note of this
make corrections...
OMG...I can't believe I didn't see that. Thank you friend. I'm done now!
