Calculating Tension for 2000kg Elevator at Rest
  • Thread starter Thread starter jasonbans
    Elevator
10 replies · 2K views · last reply
jasonbans
An elevator, complete with contents, has a mass of 2000 kg. By drawing free-body diagrams and by performing the neccesary calculations, determine the value of T ( tension) when
a) the elevator is at rest
i don't get how FN and T can be on the same Y axis together? any idea?
SammyS said:
What normal force?
the force that balance out weight ? o,o
Start by drawing the FBD. In this case, its just the y (vertical) component: m*g(weight) DOWN , tension(whats being pulled) UP. The sum of all forces(vectors so set positive and negative values for direction) equals mass*acceleration. But remember that constant velocity or at rest indicates 0 acceleration. The sum of the two forces are equal to zero. You are given the mass, and gravity(g) is 9.8m/s^2, but T is unknown. This is as much as i can do.
EDIT: is it at rest hanging, or on the ground... if the latter then ^ is wrong
Tension is related to normal force, but it has everything to do with a force in an object such as a rope or something springy at the molecular level. It's the force that keeps the object that it holds from accelerating a bit like normal force. I believe that the normal force keeps gravity from accelerating an object during contact of earth, because of inertia (resistance to gravity). So, how do you think you can turn these words into solving this problem?
"It's the force that keeps the object that it holds from accelerating a bit like normal force"
I'm not sure if my words were exactly correct here, because I think I have done a few problems where an acceleration still existed o.O? but I hope you get the point.
