Calculating Tension in a Rope with an Electric Motor
  • Thread starter Thread starter paddygills
    Tension Work
To calculate the tension in a rope lifting a 40kg mass with an electric motor at a steady speed, begin by drawing a free body diagram to visualize the forces. The key formula to use is T = mg, where T is tension, m is mass, and g is the acceleration due to gravity (approximately 9.81 m/s²). Since the mass is moving at a steady speed, the net force is zero, indicating that tension equals the weight of the mass. Therefore, multiplying 40kg by gravity gives the tension in the rope. This calculation confirms that the process is straightforward and effective for this scenario.
paddygills
how do u work out the tension of a rope ? an electric motor is used to lift a mass of 40kg at a steady speed if friction forces are ignored calculate the tension of the rope. help i have just started physics double award and do not understand this
Welcome to the PF.
You start by drawing a free body diagram (FBD) of the object (the mass), showing all the forces acting on the mass. Then you use the equation F = m * a to continue with the calculations. The F is the sum of all the forces acting on the mass m, and the resulting acceleration is a.
Show us how you start this problem now...
Neglecting friction, T = mg
Since the question indicated a steady speed, we have to assume that u > 0, and that the overall change in momentum(net force) is zero.
so do i just multiply 40kg times gravity to get the right answer
Yes it is pretty straightforward.
thanks for the help thought it was that but it seemed too easy
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
