Calculating the armature current of the motor.
  • Context: Engineering
  • Thread starter Thread starter ramox3
    Current Motor
The discussion focuses on calculating the armature current of a permanent magnet DC motor powered by a single-phase, full-wave controlled bridge rectifier connected to a 240V AC source. The rectifier absorbs 1200W of active power and 1000VAR of reactive power. Given that power loss in the rectifier is negligible, the armature current can be determined using the relationship between active power, voltage, and current. The formula to calculate the armature current is derived from the equation P = V x I, where P is the active power, V is the voltage, and I is the current.
  • Understanding of single-phase AC circuits
  • Knowledge of full-wave controlled bridge rectifiers
  • Familiarity with active and reactive power concepts
  • Basic electrical engineering principles, particularly Ohm's Law
  • Study the operation of single-phase full-wave controlled bridge rectifiers
  • Learn how to calculate armature current in DC motors
  • Explore the relationship between active power, reactive power, and apparent power
  • Investigate power factor correction techniques in AC circuits
Electrical engineering students, professionals working with DC motors, and anyone involved in power electronics and circuit analysis.
ramox3
A single-phase, full-wave controlled bridge rectifier supplies a permanent magnet dc motor. The rectifier is connected to a 240V ac voltage source and absorbs 1200W of active power and 1000VAR of reactive power from the source. If power loss in the rectifier is negligible, calculate the armature current of the motor.
I don't know where to start.. any tips would be appreciated..
Active (or real) power can be thought of as a vector at right angles to reactive power.
Magnitude of power is voltage x current
  • · Replies 41 ·
  • · Replies 16 ·
