Calculating the Charge of 3 Capacitors
  • Thread starter Thread starter freddy13
    Capacitors Charge
The discussion centers on calculating the charge of three capacitors (C1 = 3.00 µF, C2 = 8.50 µF, C3 = 15.0 µF) connected to a 24.0 V battery. The correct formula for equivalent capacitance is established as $$C_{eq}= \left ( \frac{1}{C_1+C_2} + \frac{1}{C_3}\right )^{-1}$$. After recalculating, the equivalent capacitance was found to be 6.509 µF, leading to a charge of 156.226 µC on C3. The discussion emphasizes the importance of careful arithmetic and correct formula application.
  • Understanding of capacitor configurations (series and parallel)
  • Familiarity with capacitance calculations
  • Knowledge of the formula Q = CΔV
  • Basic arithmetic skills for calculations
  • Study the principles of series and parallel capacitor combinations
  • Learn about the implications of equivalent capacitance in circuits
  • Explore error-checking techniques in electrical calculations
  • Investigate the effects of voltage on capacitor charge
Students in electrical engineering, physics enthusiasts, and anyone involved in circuit design or analysis will benefit from this discussion.
freddy13
Three capacitors having capacitance C1 = 3.00 microF, C2 = 8.50 microF and C3 = 15.0 microF are connected to a 24.0 V battery as shown. Calculate the charge on C3.
$$ C_{eq}= \left ( \frac{1}{C_1+C_2} + \frac{1}{C_3}\right )^{-1}$$
Q = CΔV
First I attempted to find the Capacitance saying that C1+C2= 11.5μC through the parallel addition of capacitors. From here, I plugged everything into the
Ceq=((1/C1+C2(1/C3))-1
equation and got my capacitance which was 2.74 μF. I took the result and plugged all of my values into the Q = CΔV equation, and got a final value of 57.096 μC, or 5.71*10-5 C.
I tried another way and got the same answer, so, any suggestions would be great. I think I messed up somewhere with the units.
Can you explain your formula for the equivalent capacitance? Are there some parentheses and an operator missing that might make the order of operations clear (and correct)?
There are more "("'s than ")"'s.
Is that: $$C_{eq} = \left ( \frac{1}{C_1} + C_2 \left ( \frac{1}{C_3} \right ) \right )^{-1}$$
or maybe: $$ C_{eq}= \left ( \frac{1}{C_1+C_2} + \frac{1}{C_3}\right )^{-1}$$
Neither of those equations nets me the same answer you got though.
I think you need to go over your arithmetic carefully.
It is the second one! Sorry for the miscommunication!
This one to be more exact!
Okay, can you run the calculation again using that formula? What value do you get for the equivalent capacitance? (The value you gave previously is not correct, although that formula is good. So... finger+calculator problems?)
I got 6.509 microF this time, does that sound correct?
Which, multiplied by the 24 V would give me 156.226 micro C, or 1.56*10^-4 C...is that right?
Yes. Much better :approve:
Thank you very much! Gotta watch those number entering errors!
14K
