morechem28
- 43
- 1
The density of Kr must be the same (or higher than) as the density of seawater 1040 kg/m3. Is that right?
The discussion focuses on calculating the new density of krypton (Kr) in a submerged balloon using principles of buoyancy and the ideal gas law. The initial density of Kr is established at 3.74 g/dm³, and participants emphasize the relationship between pressure, volume, and density as the balloon is submerged. Key equations discussed include the ideal gas law (pV = nRT) and the hydrostatic pressure equation (p = ρgh), which are essential for determining the conditions under which Kr will float or sink in water.
PREREQUISITESStudents in physics or chemistry, engineers working with gas dynamics, and anyone interested in fluid mechanics and buoyancy principles.
Why? Because you have it? If you choose a specific value ##\rho_{\text{ H}_2\text{O}}## for the density on one side of the equation, then symbol ##p## must also acquire a subscript. It needs to be narrowed down as well. If the left-hand side has no placeholders, the right-hand side must also have no placeholders. What is an appropriate subscript for ##p##? What specific pressure is it when the left-hand side is the density of seawater?morechem28 said:Firstly, I'd replace m/V on the left with that number.
Pressure at a specific depth, I think.kuruman said:Why? Because you have it? If you choose a specific value ##\rho_{\text{ H}_2\text{O}}## for the density on one side of the equation, then symbol ##p## must also acquire a subscript. It needs to be narrowed down as well. If the left-hand side has no placeholders, the right-hand side must also have no placeholders. What is an appropriate subscript for ##p##? What specific pressure is it when the left-hand side is the density of seawater?
That's exactly what we should say. You want all symbols to have subscripts. So let's see your equation.morechem28 said:Couldn't we say about the p on the right that it is the sum of p (atm) and the p (hydrostatic)?
That's not what I get. I get about 30 MPa = 300 Bars. Let's see your arithmetic and your management of units.morechem28 said:Then, p (hydr) = p (cr) - p (atm) = 307 633,87 - 101 325 = 206 308,87 Pa. Now, I would calculate the depth: p (hydr) = ρ (Kr) * h * g; h = p (hydr)/(ρ (Kr) * g). It seems way too easy to be right. :D But at least I've tried.
My answer agrees with @Chestermiller's answer.Chestermiller said:That's not what I get. I get about 30 MPa = 300 Bars. Let's see your arithmetic and your management of units.
Thank you, yes. I should divide (density*R*T) by 0,0838 kg/mol, not 83,8 g/mol. Now, I get 30.76 (p (cr)) MPa. And now, I'd do this: p(cr) - p(atm) = p(hydr), p(hydr) = 30 763 387.4 - 101 325 = 30 662 062.4 Pa. And then, given that: p (hydr) = density*h*g; h = p (hydr)/(density*g) = 3005.38 m. Is that right, please?kuruman said:My answer agrees with @Chestermiller's answer.
Do you really feel that 6 significant figures is justified for this calculation? What would your answer be for a realistic number of significant figures?morechem28 said:Thank you, yes. I should divide (density*R*T) by 0,0838 kg/mol, not 83,8 g/mol. Now, I get 30.76 (p (cr)) MPa. And now, I'd do this: p(cr) - p(atm) = p(hydr), p(hydr) = 30 763 387.4 - 101 325 = 30 662 062.4 Pa. And then, given that: p (hydr) = density*h*g; h = p (hydr)/(density*g) = 3005.38 m. Is that right, please?
Yes, I think I get it. But in accordance with the original assignment, I should consider Kr an ideal gas. I know that is not real, but the whole situation is meant to be hypothetical.Chestermiller said:Do you really feel that 6 significant figures is justified for this calculation? What would your answer be for a realistic number of significant figures?
What is the critical pressure of Krypton? Based on this, do you feel that use of the ideal gas law was accurate enough for this calculation? How would you modify the calculation to take into account the deviation from ideal gas behavior?
@morechem28, note that @Chestermiller asked you some specific questions in Post #82. But you didn’t answer any of them!morechem28 said:Yes, I think I get it. But in accordance with the original assignment, I should consider Kr an ideal gas. I know that is not real, but the whole situation is meant to be hypothetical.
No. 3005.38 m has 6 significant which is too many. The depth can’t be determined to the nearest centimetre because the data used in the calculation are not precise enough.Chestermiller said:Do you really feel that 6 significant figures is justified for this calculation?
Two or three significant figures is realistic, since the values used (see Post #1) are given to only three significant figures (and only multiplications and divisions have been used).Chestermiller said:What would your answer be for a realistic number of significant figures?
