How Do You Calculate Electric Flux Through a Rectangle?
The discussion focuses on calculating electric flux through a rectangle measuring 3.60 cm by 4.50 cm in the xy-plane, with an electric field vector E = (80.0i + 50k) N/C. The user initially calculated the area as 0.00162 m² and the magnitude of the electric field as approximately 94.34 N/C. However, the correct approach requires vector multiplication rather than magnitude multiplication, leading to an incorrect final answer of 0.15283 Nm²/C. Participants advised the user to follow the proper vector multiplication method for accurate results.
  • Understanding of electric flux and its calculation
  • Familiarity with vector operations in physics
  • Knowledge of unit conversions from centimeters to meters
  • Basic understanding of electric fields and their representation
  • Study vector multiplication in the context of electric fields
  • Learn about Gauss's Law and its application to electric flux
  • Explore examples of electric flux calculations through different geometries
  • Review unit conversion techniques for physics problems
Students studying electromagnetism, physics educators, and anyone seeking to understand electric flux calculations in practical scenarios.
arileah
Hello,
The problem:
A 3.60cm x 4.50cm rectangle lies in the xy-plane. What is the electric flux through the rectangle if E=(80.0i + 50k) N/C ?
My attempt:
First convert the rectangle units from cm to m.
4.50cm = 0.045m
3.60cm = 0.036m
Find the area of the rectangle.
A = 0.036m x 0.045m = 0.00162 m^2
Find the magnitude of the electric field.
E = sqrt (50^2 + 80^2) = 94.34 N?C (aprox.)
Multiply the two,
electric flux = E * A = 0.15283 Nm^2 / C (aprox.)
However, this answer is wrong. Could anyone point me in the right direction? Thank you.
Hello arileah, :welcome:
This looks like homework and should be posted in the homework forum -- there's a mandatory template there.
Your error is at the point where you multiply the two: that is a vector multiplication, not a magnitude multiplication.
Thank you! I am new to using physics forums. I'll post it to the homework forum.
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 29 ·
