Calculating the Speed of a 796eV Electron
  • Thread starter Thread starter skibum143
    Electron Speed
The discussion revolves around calculating the speed of an electron with an energy of 796 eV, focusing on the kinetic energy equation and unit conversions between electron volts and joules.
  • Mathematical reasoning, Assumption checking
  • Participants explore the relationship between kinetic energy and speed using the equation Ek=1/2 mv². There are attempts to convert energy from eV to joules and to solve for speed, but confusion arises regarding unit conversions and calculations.
Multiple participants are engaged in checking calculations and questioning unit conversions. Some guidance has been offered regarding the importance of using correct units, but there is no explicit consensus on the resolution of the problem.
Participants note the need to convert eV to joules for accurate calculations, highlighting the potential misunderstanding of energy units in the context of the problem.
skibum143
What is the speed of a 796eV electron?
E = hc/lambda
E = hv
I'm not sure how to get a value for meters... I know if I take h (plank's constant) and divide the electron, I will get 4.14E-15 ev*s / 796 eV = 5.20E-18 seconds, but that is just a time, i don't know how to get the distance for that time...
That energy is entirely kinetic.
Ek=1/2 mv2
If 796 = 1/2 * 9.11E-31 * v^2, I get v to be 4.18E16 m/s which is wrong...i'm not sure what I'm doing wrong...
Watch your units.
I tried converting eV to joules, which gave me 1.27E-16 joules, which gave me 8.36E6 m/s but that is wrong too. I think the units for mass (kg) are correct, I'm not sure what I have wrong...
Check your math.
For:
796 = 1/2 * mv^2 (where m = 9.11E-31) I keep getting 4.18E16 for v
I don't understand what part I'm doing wrong, I've done it about ten times...
Show how you solved for v.
eV = 1/2 mv^2
eV / (1/2m) = v^2
v = sqrt (eV / 1/2m)
Am I doing this wrong?
So far OK.
Seems to me like somehow you are misplacing 2 when calculating value.
I'm using
m = 9.11E-31
eV = 796
796 = 1/2*9.11E-31 v^2
796 = 4.55E-31 v^2
1.748E33 = v^2
v = 4.18E16
Don't know where I'm wrong...
Seems like my guess was wrong. You have ignored my earlier remark about using correct units. Sigh.
I didn't ignore it, I don't understand where my units are wrong. eV, m = kg
If you would tell me which part I'm doing wrong I could try and fix it.
Nevermind, I got it myself. I was using the wrong value to convert eV. Thanks anyway
You have to convert eV to J, from what you wrote you were assuming 796 [eV] = 1/2 9.11E-31 [kg] * x2 [m/s]2. eV is NOT kg*m2*s-2, it is about 1.602e-19 kg*m2*s-2 (or 1.602e-19 J).
  • · Replies 56 ·
