Calculating the Starting Angle of a Pendulum Using Geometry and Trigonometry
  • Thread starter Thread starter ptdreamer
    Angle Pendulum
The discussion revolves around determining the starting angle of a pendulum bob using geometric and trigonometric principles. The scenario involves specific measurements related to the pendulum's setup, including distances and diameters.
  • The original poster attempts to use the arcsine function to find the angle but expresses uncertainty about the approach. Some participants question the clarity of the angle being determined and suggest providing a drawing for better understanding.
Participants are exploring the geometric aspects of the problem, with some guidance offered regarding the use of the arcsine function. There is an ongoing clarification of the problem context, particularly regarding the pendulum's motion.
The original poster refers to specific measurements and a nominal distance, indicating constraints in the problem setup. There is an assumption that the pendulum is in motion, which is being discussed but not confirmed.
ptdreamer
A student wishes to figure out the starting angle of the pendulum bob in this experiment. The 50 cm mark is directly below the point of support of the pendulum and the distance from the point of support to the center of the bob is 120 cm. The student measures the diameter of the pendulum bob to be 1.04 cm and the diameter of the post to be 0.709 cm.
What is the starting angle (in radians) of the pendulum when the post is at nominal distance 86.6 cm?
I think the equation I should use is A= sin -1 (delta X corr/L)
... but I am not sure how to go about this.
Please help!
Welcome to PF.
Perhaps you could describe what angle it is you are trying to determine a little more clearly. Is the pendulum in motion?
You might be better served to provide a drawing.
that is the exact question that the professor gave and i am assuming that the pendulum is in motion.
this is the picture that seemed to relate to this problem.
i hope that you can help!
That's just a matter of geometry then isn't it?
And your arcsine of the ratio looks just fine to give you the angle.
24K
