Calculating the total power received by an antenna
The discussion focuses on calculating the total power received by a radar antenna transmitting 50kW at 10 GHz, with a narrow beam area of 1m². The power reflected from an aircraft is only 1% of the transmitted power, and the aircraft is located 100km away. The total power received by the antenna is calculated to be 0.266 W, considering the permittivity and permeability of free space and a conductivity of 10^-7 S/m.
  • Understanding of radar technology and antenna theory
  • Knowledge of electromagnetic wave propagation
  • Familiarity with power calculations in RF systems
  • Basic principles of permittivity and permeability in free space
  • Study the principles of radar signal reflection and scattering
  • Learn about the calculations involved in antenna gain and directivity
  • Explore the effects of distance on signal strength and power loss
  • Investigate the role of conductivity in electromagnetic wave propagation
Engineers and scientists working in radar technology, telecommunications professionals, and students studying electromagnetic theory will benefit from this discussion.
enginej
Thread moved from the technical forums, so no Homework Template is shown
A radar antenna transmits 50kW at 10 GHz. Assume transmission is in a narrow beam, 1m^2 in area, and that within the beam, waves are plane waves. The wave is reflected from an aircraft but only 1% of the power propagates i the direction of the antenna. If the airplane is at a distance of 100km,
Calculate: The total power received by the antenna. Assume Permittivity and permeability of free space and conductivity of 10^-7 S/m.
ANSWER: The answer is 0.266 W (I can't seem to get it.)
Can you show what you have attempted, so far? Then we will make suggestions to guide you.
Thanks for the interest, I already attached the PDF file of my work, let me know if you can't see it.
I also attached a second attempt of the problem, to this post.
I missed that there is a file attached. I will take a look.
  • · Replies 69 ·
  • · Replies 28 ·
25K
11K
  • Poll Poll
