Calculating the volume of a function that rotates around the x-axis
  • Thread starter Thread starter jakobs
    Function Volume
The problem involves calculating the volume of a solid formed by rotating the function y = (1/x) around the x-axis, specifically between the limits x = 1 and x = 2.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the setup of the integral for volume, with some focusing on the correct application of the formula for volumes of revolution. There are attempts to clarify the evaluation of the integral and the antiderivative process. Others explore the method of cylindrical shells and express confusion about the results obtained.
Some participants have provided guidance on evaluating the integral and correcting assumptions about the shell radius in the cylindrical shells method. Multiple interpretations of the problem are being explored, particularly regarding the formulas used for volume calculation.
There are references to specific calculus textbooks and formulas, indicating that participants are drawing from established methods while also questioning their application in this context. Some participants express uncertainty about their previous calculations and seek clarification on the correct approach.
jakobs
y=(1/x) is rotating around the x-axis.
find the volume for the figure between x=1 and x=2
V=pi y2 = pi*(1/x)2
V= 1∫2 pi(1/x)2dx which gives V= 1∫2 pi(1/x2)dx
A primitive function for (1/x2) is -(1/x)
V=1∫2 pi((-(1/2))-(-(1/1)))
How do I go from here?
Why are you multiplying in your last line:
V=∫21 (pi)...
Once you have the antiderivative , you evaluate the antiderivative at the endpoints
2,1 respectively, and that is the value of the integral.
Sorry, I posted wrong, don't know what happened.
but pi*(-(1/2))=-1,57
pi*(-(1/1))=-3,14
-1,57-(-3,14)= 1,57
is this the right answer?
Yes, but a nicer answer would have been [itex]\frac{\pi}{2}[/itex] units3.
V=pi y2 = pi*(1/x)2
Easily stated you want :
[itex]2π\int_{1}^{2}\frac{1}{x^2}dx[/itex]
You could have also used :
[itex]π\int_{1}^{2}1dx[/itex]
The OP correctly identified the volume of revolution to be [tex]V = \pi\int_{1}^{2} \frac{1}{x^2} dx.[/tex]
What mathematical reasoning gives this?
CAF123 said:
The OP correctly identified the volume of revolution to be [tex]V = \pi\int_{1}^{2} \frac{1}{x^2} dx.[/tex]What mathematical reasoning gives this?
There are two formulas I remember from Stewart calc 4th edition which highlight the formulas to use when calculating volumes of solids.
[tex]\pi\int_{a}^{b}xf(x)dx[/tex]
[tex]2\pi\int_{a}^{b}f^2(x)dx[/tex]
I have come across the method of cylindrical shells, where for some rotation about y axis, [tex]V = 2\pi \int_{a}^{b} x f(x) dx[/tex]
I was wondering if someone could attempt the problem in the OP using cylindrical shells, because I am always getting either π or π/4, not the required π/2.
You've remembered incorrectly.
Show us what you tried. You should have had to split it up into two integrals.
I split it up into 2 regions: one integral using y limits from 1/2 to 1 and another from 0 to 1/2.
For the first region: [tex]V = 2\pi \int_{\frac{1}{2}}^{1} (\frac{1}{2} + y)(\frac{1}{y} - 1) dy ,[/tex] where the shell radius is 1/2 + y and it's height is 1/y - 1.
Then the region using y limits 0 to 1/2 was a rectangular region:
[tex]V = 2\pi\int_{0}^{\frac{1}{2}} y dy,[/tex] where the height is a constant 1 unit.
Doing the integral does not give me the correct answer. Where am I going wrong?
Many thanks.
The shell radius in the first integral should simply be y.
Perfect, I must have thought that I was rotating about the line y = 1/2 at my first attempt, but I see why it is simply y: y is the distance from the axis of rotation, which is the x axis. I now have the correct answer.
Thanks again.
It would be a good idea for you to review formulas that you "remember" to see if they are actually valid. The one above has nothing to do with this problem.
  • · Replies 20 ·
