Calculating Torque Needed to Stop Flywheel
  • Level: Undergrad
  • Thread starter goelvaibhav
    Flywheel Torque
1 reply · 5K views · last reply
goelvaibhav
Torque required!
Hi,
Problem Statement:
A flywheel with Moment of Inertia I, and rpm w1 is rotating. It has a shaft at is center which is attached to a gearbox (1:100) at one end. The output shaft of the gearbox will rotate at w1 x 100. The other end of the shaft of the flywheel will rotate at w1.
Now, I need to stop the flywheel in 't' sec. Will the torque required to stop the flywheel will be the same at both the ends?
Vaibhav
Welcome to PF!
Hi Vaibhav! Welcome to PF! :smile:
(have an omega: ω :wink:)
Yes, for a particular acceleration α, torque = Iα …
I is the same, so the torque will be the same whichever end you apply it. :smile:
