Calculating torque within a DC MOTOR?
Calculating torque in a DC motor requires understanding the Lorentz force law, expressed as F = ILB, where F is the magnetic force in Newtons, I is the current in Amperes, L is the length of the conductor, and B is the magnetic field strength in Tesla. The torque (T) can be calculated using the formula T = F x r, where r is the rotor radius. Accurate measurements of current, conductor length, and magnetic field strength are essential for precise torque calculations. The magnetic field strength can be measured in either Tesla or Gauss, with 1 Tesla equating to 10,000 Gauss.
  • Understanding of the Lorentz force law (F = ILB)
  • Knowledge of torque calculation (T = F x r)
  • Familiarity with units of measurement (Newtons, Amperes, Tesla, Gauss)
  • Ability to use a multimeter for current measurement
  • Research the Lorentz force law in detail and its applications in electromagnetism.
  • Learn about torque calculations in electric motors, focusing on the relationship between force and radius.
  • Study the conversion between Tesla and Gauss for magnetic field strength measurements.
  • Explore the use of multimeters for measuring current in electrical circuits.
Electrical engineers, physics students, hobbyists working with DC motors, and anyone interested in understanding the principles of electromagnetism and torque calculations.
Momento
The torque that is generated inside a magnetic motor is caused from the magnetic forces that is this formula:
F = ILB
F: Magnetic force(Not sure what the unit would be...)
I: Current(A)
L: Torque(N.m)
B: Magnetic field.( Gauss or Tesla?)
I just need some help in calculating the total magnetic force I know the current & the magnetic field(measured in Tesla or Gauss in this cause?). However, the Torque is confusing for me to calculate... I've looked around and read theses slide countlessly but I really don't know how? I end up scratching my head all night wondering how to calculate the torque!
Thanks in advance!
Hi Momento. Suggest recheck your textbook (or the web) again to establish what that "L" quantity is.
My understanding is such that:
F = I l B (sin Θ = 1 )
where F = Newtons, I = amps, l = conductor length, and B = magnetic field strength in Tesla.
(remnant field strength may be .7 * max stated value)
You could also use a motor 'constant':
where torque in Nm/A = K * I, and BEMF = Kω
such that K = 2NBLR
where N = # of turns, B = Br*t/(t+g), L = active length (of stator), R = effective radius
where Br = remanent flux density, t = magnet thickness, and g = air gap
I'll give it a look.
such that K = 2NBLR
"(remnant field strength may be .7 * max stated value)"?
All the rest is really confusing... Could you simplify it more and more...?
Hello,
Calculating torque within a DC motor involves understanding the relationship between magnetic force, current, and magnetic field. The formula you have provided, F = ILB, is known as the Lorentz force law and is used to calculate the force on a charged particle moving through a magnetic field.
In this case, the force (F) is equal to the current (I) multiplied by the length of the conductor (L) and the strength of the magnetic field (B). The unit for magnetic force can be expressed in Newtons (N) or Ampere-meters (A.m). The unit for torque is Newton-meters (N.m).
To calculate the torque in a DC motor, you would need to know the length of the conductor (L) and the strength of the magnetic field (B). The current (I) can be measured using a multimeter. Once you have these values, you can use the formula F = ILB to calculate the magnetic force, and then use the torque formula, T = F x r, where r is the radius of the rotor, to calculate the torque.
It is important to note that the magnetic field strength (B) is typically measured in Tesla (T) in the SI system, or in Gauss (G) in the CGS system. To convert between the two, 1 Tesla is equal to 10,000 Gauss.
I hope this helps you in your calculations. If you have any further questions, please let me know. I am always happy to help others understand and apply scientific concepts.
Best regards,
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 24 ·
