Calculating Total Current in Cylindrical Wire at 60 Hz
To calculate the total current in a cylindrical wire at 60 Hz, use the formula I = σAωE, where σ is conductivity, A is the cross-sectional area, ω is angular frequency, and E is the electric field. The electric field can be determined using E = V/d, where V is voltage and d is the distance between the wire's ends. For AC, the total current can also be found using I = JmaxA, with Jmax being the maximum current density. For DC, apply Ohm's law, I = V/R, where R can be calculated as R = ρl/A. Seeking assistance from a tutor or instructor may provide additional clarity on these calculations.
AC
I have a thick cylindrical wire that I make it 10 smaller pieces and the area remains constant. How do I find the toatal current at 60 Hz? given sigma, miou, and radious
I also need to find the total current for a given maximum current density that was given for the thick wire for AC. How to??
and same for DC?
thanks in advance
I am really stuck with this problem and problem 9.36 griffiths 3rd edition
anyone has suggestions?
thanks for the help
nobody knows?
To calculate the total current in a cylindrical wire at 60 Hz, you will need to use the formula for total current, which is given by I = σAωE, where σ is the conductivity of the material, A is the cross-sectional area of the wire, ω is the angular frequency (2πf) and E is the electric field.
To find the total current, you will first need to calculate the electric field. This can be done using the formula E = V/d, where V is the voltage and d is the distance between the ends of the wire.
Once you have calculated the electric field, you can plug in the values of σ, A, ω, and E into the formula for total current to find the total current at 60 Hz.
To find the total current for a given maximum current density for AC, you can use the formula I = JmaxA, where Jmax is the maximum current density and A is the cross-sectional area of the wire. Simply plug in the values and you will get the total current.
For DC, the total current can be found by using Ohm's law, which states that I = V/R, where V is the voltage and R is the resistance of the wire. In this case, the resistance can be calculated using the formula R = ρl/A, where ρ is the resistivity of the material, l is the length of the wire, and A is the cross-sectional area. Once you have calculated the resistance, you can use Ohm's law to find the total current.
I hope this helps with your problem. If you are still stuck, I would suggest seeking help from a tutor or your instructor. They will be able to provide more specific guidance and help you understand the concepts better. Good luck with your studies!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
