Calculating Velocity and Position of a Car Over Time Using Equations
  • Thread starter Thread starter thaaampie
The problem involves calculating the velocity and position of a car that accelerates and then decelerates over time. It is set within the context of kinematics, specifically focusing on motion under constant acceleration and deceleration.
  • The original poster attempts to establish equations for velocity and position based on the car's acceleration and deceleration phases. Some participants question the setup of the equations and the interpretation of the problem, while others suggest providing initial attempts to facilitate guidance.
The discussion is ongoing, with participants exploring different aspects of the problem. Some guidance has been offered regarding the relevant equations, but there is no explicit consensus on the approach to take or the specific setup of the equations.
The original poster expresses uncertainty about setting up the equations, indicating a potential gap in understanding word problems. There is also a mention of needing to determine the car's velocity after the first 10 seconds to answer subsequent questions.
thaaampie
A car starts at rest, and at time t=0 accelerates at a constant rate of 2 ft/sec^2 for 10 seconds. Then the car decelerates at a constant rate of -1 ft/sec^2 until it stops.
Write the equations for the velocity and the position for time t, where o<=t<=10.
Write the equations for the velocity and the position for time t, where t=> 10.
When did the car stop, and how far did it go?
If you would show your attempt at the problem then I will be able to help you with it. However, without anything more then the problem, it is impossible to tell what you are having problems with.
That's the problem, I'm not exactly sure how to set up the equations for the problem. Word problems are not my forte.
The formulas you will need are the following:
x=v_1+\frac{1}{2}at^2
v_2=v_1+at
The initial velocity and accelerations are given, therefore that should answer your first two questions after plugging everything in.
In order to solve the last question, you must first determine the car's velocity after the first 10 s (using the second equation listed above). Then you can use that velocity to find the time required to stop (using the same equation).
If you need some more help with this problem, don't hesitate to post back.
  • · Replies 24 ·
