Calculating Velocity and Time of a Horizontal Projectile
  • Thread starter Thread starter davo
    Velocity
The problem involves a rock being thrown horizontally from a height of 50 meters, with the goal of determining the time it was in the air and the initial velocity of the rock. The rock lands 70 meters away from the base of the building.
  • Participants discuss the setup of the problem, with some suggesting that the vertical motion can be treated independently of the horizontal motion. Questions arise regarding the interpretation of variables and the equations used.
There is an ongoing exploration of the equations of motion relevant to the problem. Some participants have provided insights into how to approach the vertical motion, while others are questioning their algebraic manipulations and interpretations of the variables involved.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a focus on clarifying the definitions of terms used in the equations.
davo
A person throws a rock horizontally from the roof of a 50m building. The rock lands 70 m from the base of the building.
How long was the rock in the air in s?
I got 3.194. The online home work thingy (webassign) said I was right.
With what velocity was the rock thrown in m/s?
I used the Xf equation and solved for time. Dont I just plug in the time i got in the last equation and actualy solve it? Well i tryed that but I just keep getting it wrong.
70=-4.9(3.194)^2 + Vo(3.194) Is this right?
The way you need to set it up is imagine the rock is simply dropping because the x velocity doesn't matter. So s = vt + 1/2 at^2 s = 50m v = 0 a = 9.8m/s^2
50 = 0t + 1/2 9.8 t^2
what does s represent in this?
I think i did my algebra wrong because it said it was wrong.
(49.88+50)/3.194= 31.305
sorry s is displacement
50 = 0t + 1/2 9.8 t^2 this is the equation, the height 50 is equal to zero plus 1/2 9.8*t^2 (the rock is modeled as only dropping from 50 meters above the ground the x velocity has nothing to do with it)
  • · Replies 18 ·
