Calculating Velocity & Kinetic Energy After Explosion
In summary, an object with total mass of 14.4 kg is sitting at rest when it explodes into three pieces. One piece with mass of 4.9 kg moves up and to the left at an angle of 22° above the –x axis with a speed of 26.8 m/s. A second piece with mass of 5.1 kg moves down and to the right an angle of 27° to the right of the -y axis at a speed of 20.9 m/s. The third mass of 4.4 kg moves neither up nor to the left nor down but instead remains at rest. The x-component of the velocity of the third piece is -26.8 m/s. The y-component
monkey89
An object with total mass mtotal = 14.4 kg is sitting at rest when it explodes into three pieces. One piece with mass m1 = 4.9 kg moves up and to the left at an angle of θ1 = 22° above the –x axis with a speed of v1 = 26.8 m/s. A second piece with mass m2 = 5.1 kg moves down and to the right an angle of θ2 = 27° to the right of the -y axis at a speed of v2 = 20.9 m/s. The third mass m3 = 4.4kg.
What is the x-component of the velocity of the third piece?
What is the y-component of the velocity of the third piece?
What is the magnitude of the velocity of the center of mass of the pieces after the collision?
Calculate the increase in kinetic energy of the pieces during the explosion.
Any help would be wonderful and greatly appreciated Thank you.
what have you tried? what's not working for you?
Im not sure where to start this problem. Which equation to use.
Momentum is going to be conserved, so the momentum of the ball before it explodes is equal to the sum of the momentums of the 3 pieces
So m1v1+m2v2+m3v3/m1+m2+m3
If the object was initially at rest then its momentum was zero, that means that:
[tex]
m_1v_1 + m_2v_2 + m_3v_3 = 0
[/tex]
It also means that the horizontal components of momentum will add to give zero as will the vertical components.
I already tried zero and it didnt work. I don't know what else to try.
Show exactly what you did.
What did you get for the x and y components of the momentum of m1 and m2?
are you trying to solve a simultaneous system of equations of 2 equations and 2 unknowns?
Because I think that's where the solution is...you need to take that equation given by JHamm and break it down into x and y components, along with the unknown x and y components of the 3rd mass...don't worry about the angle of it, just yet, just get the x and y components of the velocity and THEN you can do a vector sum of those to get the result.
My home work is aon a site called smart physics. I can in put an answer and it will tell me if I am right or wrong. I put in zero and it didn't work. I don't know which equation to use or how to find which equation to use.
actually, it's not even two equation two unknowns...it should be one equation one unknown, twice...very simple...why don't you show what you are trying to do?
I just tried to input zero with any equation. The reason i did this was because i don't know what to do. So i was just tring to see if any of the answers would be zero. I don't know which equation to use to start these problems
It is not a matter of guessing an answer, punch it in the site and see if it is right or wrong...you actually need to solve a couple of equations...have you understood this part yet?
You have been told that the sum of the momentum from all 3 pieces was zero before the explosion and will remain zero after the explosion.
The equation you need to work with has been already posted and you were even told that all you have to do is break it down into x-components and y-components and that each equation still equals zero, from where you should be able to come up with an answer...
...this is a lot of explanation...longer that would have taken me to solve the problem.
hope this helps...
gsal; I don't think you did a good job explaining. I too am at a loss on what to do and I have found the velocity of the third particle. What I don't know what to do is how to actually break it down into the x-component and the y-component!
For the y component you multiply the velocity by the sine of the angle it makes with the x axis, for the x component you multiply the velocity by the cosine of that angle.
In other words the first one is moving at 26.8m/s at an angle of 22 degrees, so...
[tex]
V_1_x = -26.8\cos{22^o}
[/tex]
The negative is there because it is moving towards the negative x direction.
[tex]
V_1_y = 26.8\sin{22^o}
[/tex]
Where did you get -28.6? I tried -28.6cos(22)/26.8= x
This is what you ment right?
Sorry, it should read 26.8 not 28.6, I've fixed it now
V_1_x = -26.8\cos{22^0}
I tried to do this equation in my calculator -26.8 divided by cos(22^0). Is this what you ment? I am sorry for all the questions I am tring to really understand physic.
Related to Calculating Velocity & Kinetic Energy After Explosion
1. How do you calculate the velocity of an object after an explosion?
To calculate the velocity of an object after an explosion, you can use the equation v = s/t, where v is the velocity, s is the distance traveled by the object, and t is the time it takes for the object to travel that distance. You can measure the distance traveled by the object and the time it takes for the object to travel that distance using various tools such as a stopwatch and a measuring tape.
2. What is the formula for calculating kinetic energy after an explosion?
The formula for calculating kinetic energy after an explosion is KE = 1/2 * m * v^2, where KE is the kinetic energy, m is the mass of the object, and v is the velocity of the object. This equation is derived from the basic definition of kinetic energy, which is the energy an object possesses due to its motion.
3. How does the mass of an object affect its velocity and kinetic energy after an explosion?
The mass of an object does not directly affect its velocity after an explosion. However, it does affect the kinetic energy of the object, as shown in the formula KE = 1/2 * m * v^2. A heavier object will have a higher kinetic energy than a lighter object with the same velocity. This is because the kinetic energy is directly proportional to the mass.
4. Can the velocity of an object after an explosion be negative?
Yes, the velocity of an object after an explosion can be negative. This means that the object is moving in the opposite direction of its initial motion. For example, if an object is initially moving to the right and the explosion causes it to move to the left, the velocity would be negative.
5. How is the energy of an explosion related to the velocity and kinetic energy of the objects involved?
The energy of an explosion is directly related to the velocity and kinetic energy of the objects involved. This is because the energy of an explosion is the result of the conversion of potential energy (stored energy) into kinetic energy (energy of motion). The higher the velocity and kinetic energy of the objects involved, the more energy is released in the explosion.
