Calculating Velocity Using Work and Friction
  • Thread starter Thread starter rsala
    Velocity Work
4 replies · 13K views
rsala
A skier moving at 5.00 m/s encounters a long, rough horizontal patch of snow having coefficient of kinetic friction 0.220 with her skis. the patch is 2.9 meters long.
what is her velocity after passing the patch?
problem must be solved by using work, avoid Newtons
work = fs
work = [tex]K_{final} - K_{initial} =- \frac{1}{2}m v^{2}_{final}- \frac{1}{2}m v^{2}_{initial}[/tex]
let s be displacement (2.9m)
[tex]-\mu_{k}mg*s = - \frac{1}{2}m v^{2}_{final}- \frac{1}{2} m v^{2}_{initial}[/tex]
m is irrelevant, factor it out and cancel.
[tex] -\mu_{k}g*s = - \frac{1}{2} v^{2}_{final}- \frac{1}{2} v^{2}_{initial}[/tex]
solve for [tex]v_{final}[/tex]
[tex]\frac{-\mu_{k}gs+.5v^{2}_{initial}}{-.5} = v^{2}_{final}[/tex]
[tex] \sqrt{-2(-\mu_{k}gs+\frac{1}{2}v^{2}_{initial})} = v_{final}[/tex]
[tex] \sqrt{ -12.4952}[/tex]
cannot take sqrt of negative number.
i can't go beyond this part, is there a solution?
[tex] \mu_{k}g*s = \frac{1}{2} v^{2}_{initial}- \frac{1}{2} v^{2}_{final}[/tex]
Where are you finding all the extra minus signs?
rsala said:
in which part
All over. Look at your first expression for K_(final)-K(initial). That's supposed to be the difference of two kinetic energies, not the negative of their sum.
o I've messed my formula up =/
i got correct answer now, thanks
