Calculating voltage between two points using line integrals
8 replies · 3K views · last reply
lys04
If the voltage between two points is the negative integral from A to B of Edl, then in a given problem where it asks me to find the voltage between two points, how do I know which is A and which is B? Will both a negative and positive answer be accepted since its relative, like for example point A is +2V compared to B but B might be -2V compared to A?
  • Equations: delta V_AB = V(x_B) - V(x_A), equal to minus the integral from x_A to x_B of E-vector dot dl-vector.
"between" is symmetric. It does not imply a direction, so the answer would be a magnitude. But is that the word used in the question?
My usage of the word voltage, with which some PF users disagree, is to denote the absolute value of the potential difference between two points. If I want to refer to a quantity that could be positive or negative, i use "the electrostatic potential difference between from A to B".
When one writes ##Q=CV## for a capacitor, ##V## is called the voltage across the capacitor and is assumed to be always positive.
Between? Did you mean "the electrostatic potential difference from A to B"?
No, I am just asking generally, it hasn't come up in a question. It just confused me tho. Does magnitude mean it's always positive?
Idk, I saw a question online that was like find the potential difference between A and B so I got confused.
Handwritten worked solution: potential difference found as the negative integral of E dr from r0 = 1 m to rf = 8 m for E = 3r^2 + 5 V/m, giving ΔV = -546 V.
:ok:That makes sense. Thanks.
That's what I meant. I crossed out the superfluous "between". Thanks for the catch.
The question in @haruspex's post #4 was addressed to me. It was a typo that I fixed. Sorry about the confusion.
But in circuit analysis you have to get the sign of the potential difference right. All these sign problems usually go away when you remember, how the corresponding quantities are derived from Maxwell's equations.
