Calculating Volume of Revolution: Solving for Unknowns Using Equations
  • Thread starter Thread starter delsoo
    Revolution Volume
10 replies · 2K views
delsoo
https://www.physicsforums.com/attachments/69284
i have done the part a, for b , i use the key in the (circled part equation ) into calculator .. my ans is also different form the ans given. is my concept correct by the way?
after adding pi, my ans is 2.80... the ans is 5.047746784, which part is wrong?
It would be a good idea here to use vertical line segments, otherwise you're going to have to set up multiple integrals. So leave everything as ##y(x)##, then:
##r_{in} = 0##
##r_{out} = 1 + \frac{1}{4x^2 + 1}##
##height = dx##
##dV = 2\pi(\frac{r_{in} + r_{out}}{2})(r_{out} - r_{in})(height)##
Integrating the volume element should give you the answer you want.
delsoo, your method is fine and I seem to get the same definite integral as you (which gives the correct answer too). The definite integral you have to evaluate is:
$$\pi\int_0^{1/2} \left(1+\frac{1}{4x^2+1}\right)^2\,dx$$
If you drop the factor of ##\pi##, you should get 1.60675.
Use the substitution ##2x=\tan\theta## to make things easier.
Erm this is misleading.
The answer is indeed 5.04775 complements of wolfram:
http://www.wolframalpha.com/input/?i=integrate+2pi%28+%281%2B+1%2F%284x^2%2B1%29%29%2F2+%29%281%2B+1%2F%284x^2%2B1%29%29+from+0+to+1%2F2
Can you please explain to me how my statements are misleading? :)
Your integrand is fine, it's just the answer you got I was worried about.
I must be missing something but what is the problem with the answer I wrote? Are you talking about "1.60675"? :confused:
Yeah I wasn't sure why you wrote that.
Ah, I think I worded it poorly. What I meant was this:
$$\int_0^1 \left(1+\frac{1}{4x^2+1}\right)^2\,dx=1.60675$$
And I feel delsoo did some mistake while evaluating the above definite integral.
