Calculating Work Done by Force on a Block
The discussion revolves around calculating the work done by a force on a 100 kg block being pulled at a constant speed of 3 m/s. The applied force is 145 N at an angle of 37 degrees above the horizontal. The user initially calculated work using kinetic energy equations, yielding 450 W, but questioned the validity of this result. They then correctly applied the power formula, resulting in a value of approximately 347.41 W, confirming that power is indeed the rate at which work is done. The conversation concludes with the user feeling satisfied after clarifying their understanding of the concepts involved.
lauriecherie
A 100 kg block is pulled at a constant speed of 3 m/s across a horizontal floor by an applied foce of 145 N directed 37 degrees above the horizontal. What is the rate at which the force does work on the block? _____ W
work = force (dot product) displacement
work = .5m * v^2 (final) - .5m *v^2 (initial)
i used the second equation and plugged in my mass as 100kg and my final velocity as 3. so i got .5(100)(3^2) = 450 W. That seems like an awful lot to me ?
Its the rate at which force does work.
What is the rate at which work is done known as?
Is it power?
This is something else I've tried.
Power = work / time = force (dot product) displacement = force * average velocity * cos(37 desgrees). I cam out with 347. 41 W. Am I doing this correctly?
Solved. Thanks for jogging my memory!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
