Calculating work from a quasi-static process for an ideal gas
  • Thread starter Thread starter trah22
    Graph Work
The discussion centers on calculating the work done during the quasi-static expansion of an ideal gas, where pressure is defined as P = αV² with α = 5.00 atm/m⁶. The work done is derived from the integral W = -∫P dV, leading to the expression W = -α(V³/3) evaluated from the initial volume of 1.00 m³ to the final volume of 2.00 m³. The correct calculation yields W = -1.2 x 10⁶ J, confirming that the factor of 1/3 arises from integrating V². The participants clarify the setup of the integral and the necessity of the 1/3 factor in the final answer.
  • Understanding of ideal gas laws and properties
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of quasi-static processes in thermodynamics
  • Experience with pressure-volume work calculations
  • Study the derivation of work done in thermodynamic processes using W = ∫P dV
  • Learn about the implications of quasi-static processes in thermodynamics
  • Explore the principles of ideal gas behavior and related equations
  • Review integration techniques for polynomial functions in calculus
Students studying thermodynamics, particularly those focusing on ideal gas behavior and work calculations in physics courses, as well as educators seeking to clarify concepts related to quasi-static processes.
trah22
a sample of ideal gas is expanded to twice its original volume of 1.00m^3 in a quasi-static process for which P=alphaV^2, with alpha=5.00 atm/m^6. How much work is done on the expanding gas.
w=-intergral sign Pdv from intial to final volume( i don't know how to type this out)
w=-aplha(v^3/3) from 2m^3 to 1m^3
=(-5.065 x10^5/3)(2^3-1^3)=-1.2x10^6
this actually the correct answer, however i don't understand why -5.065x10^5 is being divided by3 i thought it would be : -5.065x10^5((2^3/3)-(1^3/3)=w/e could someone explain why your suppose to set it up like that...
Hint:
What is
\int\alpha x^2 dx
alpha)(x^3/3)... did i forget something
What is the work done in a reversible quasistatic process? It is given by
W = \int P dV
Thats how the factor of 1/3 comes about. Maybe the answer is wrong?
(PS--Which book is this?)
the text is principles of physics serway and jewett 4th edition, is the correct setup to the anser then -5.065x10^5(2^3/3-1^3/3) or the way they put it? Should the 1/3 still be factored out?
  • · Replies 21 ·
