Calculating Work: When to Use W = Fd cos(a) vs. the Integral of F
  • Thread starter Thread starter caspeerrr
    Work
The discussion clarifies the application of the work formula W = Fd cos(a) versus the integral of force (F) in physics. W = Fd cos(a) is applicable when the force is constant and acts along a straight path, such as pushing an object at a constant speed. Conversely, the integral of F is used when the force varies along the path of integration, such as in scenarios involving changing forces. Examples provided illustrate these distinctions effectively.
  • Understanding of basic physics concepts, particularly work and force.
  • Familiarity with the formula W = Fd cos(a).
  • Knowledge of integration in calculus.
  • Ability to analyze problems involving variable forces.
  • Study examples of constant force scenarios using W = Fd cos(a).
  • Explore problems involving variable forces and the application of the integral of F.
  • Review calculus techniques for integrating force functions.
  • Examine real-world applications of work calculations in physics.
Students in physics courses, educators teaching mechanics, and anyone seeking to understand the principles of work and force in physical systems.
caspeerrr
When do you use W = Fd cos(a) and when do you use the integral of F?
W = Fd cos(a) Integral of F
When doing exercises it seems random to me when I have to use the formule W = fd cos(a) and when I have to use the integral? What is the consistency in this?
Thanks!
Thanks!
It would help if you could give a few examples. Can you post 1-2 of each type of problem? In general you integrate if something is changing along the path of integration. If things are constant along the path (like pushing a block at a constant speed across a floor), then you can just use W=Fd.
11K
